Ignition Tumbler removal 944 Turbo
Can anyone please advise how to remove the ignition tumbler from the housing on my 1988 944 Turbo. I already have the housing out of the car, I just need to know how to remove it(tumbler) from the housing so I can install the new one. Thanks Tony
In the Fires of Hell.....
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost 1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th 1987 944S - Restored salvage title, ready to live again I can fix your late 944 Cruise Control module - PM for details |
Tumbler replacement
Thanks for quick response, really appreciated.Not sure where to measure from. For instance is the 18.5mm measured from the raised center line that goes down the center in the diagram or to the outer edge of the housing(right of the center line)?
Tony |
Thread Tools | |
Rate This Thread | |
