Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Porsche Crest No spark sometimes no fuel.
I've been trying to get my 951 started for about 4 months since the time it didn't start in June. At first it wasn't sending power to the fuel pump, so I replaced the DME relay and fuel pump fuse. After that it still didn't run the pump. I tried using a jumper for the relay and it did run the pump, but the car didn't start. I checked the plugs and it was getting fuel since they were fouled and smelled, but they didn't spark even with a test light. I checked the ignition coil and it was getting 12 volts to all three terminals. I tested the resistance, and the black terminal + the green terminal tested only 0.1 ohms above spec, at 0.7 ohms. The green terminal + the output to the distributor was more than in spec at about 5800 ohms. Could this keep it from sparking at all? It seems like such a small amount out of spec that you would think it'd at least have a weak spark. Thanks for your help.
Old 10-15-2020, 08:09 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Are you getting a tach bounce? Is your battery fully charged? How old is the gas? Is the engine block grounded to the rest of the car? These are things I would check in this order. Keep us updated on your progress.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 10-16-2020, 08:00 AM
There is tach bounce, the battery has been on a tender for months, the gas is only a few weeks old, and I don't know how to check the ground. The car has no rust, so I don't think the ground would just come off by itself.
Old 10-16-2020, 04:44 PM
In the Fires of Hell.....
kdjones2000's Avatar
Sounds like a computer issue, but you should really follow the DME test plan for your troubleshooting.
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 10-17-2020, 02:38 AM
How would I go about doing that?
Old 10-17-2020, 01:44 PM
Super Moderator
nize's Avatar
Engine Starting and Running Troubleshooter
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 10-18-2020, 07:01 AM
Thanks, I'll check it out.
Old 10-18-2020, 11:34 AM
It's not a DME relay since I got a new one and tested both of them. It's not a fuel pump because it runs with a jumper on the DME relay. It's not a fuel pump fuse because I've replaced it with a known good one. I know it's not reference or speed sensors because I'm getting tach bounce. Although I'm not sure about the DME control unit, security system, or the ignition system. I think the security system is most plausible though since there is neither spark nor fuel, but I can't find the security module under the passenger side footwell. The plot thickens.
Old 10-18-2020, 11:43 AM
Mine was missing too but was replaced by a connector that jumped the wires to bypass the alarm. Unfortunately the spade connectors in the matting connector were crap and gave a intermittent starting. I got sick of that and just used nice sealing butt connectors and haven't had a problem in 3 years.
https://www.pelicanparts.com/techarticles/Porsche_944_Turbo/36-ELEC-Troubleshooting_the_Alarm_System/36-ELEC-Troubleshooting_the_Alarm_System.htm
Mike G.
Old 10-20-2020, 06:20 AM
