Kessel run in 12 parsecs!
Dash lights
Do I have to pull my steering wheel to access the back of the guage cluster, my lights are dim and I want an easy fix. Also my volt meter seems go top out at the top of the gague and it jumps down, bad gague?
Keep cool man.. ![]() |
17 looks, 0 answers, hmmm...
In the Fires of Hell.....
'86 usually don't require you to pull the steering wheel, but it's easier to do so.
Airbag cars need the wheel removed. Who knows about your gauge, could be bad connections, broken flex PC board as well.
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost 1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th 1987 944S - Restored salvage title, ready to live again I can fix your late 944 Cruise Control module - PM for details |
Super Moderator
i don't think it's a bulb; the 951 has some silver foil paint on the back that helps the fiber optics reflect light so it's brighter, and that paint degrades over time. i recall reading a how-to instructions on fixing it yourself, but don't have the time to dig it up right now. you might want to try googling around and post what you find here.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black with maroon interior All stock with shimmed WG |
Wow, thats pretty cool, Thanks gang....
![]() There are two other areas where LED bulbs are a dramatic improvement. Engine bay: ![]() ...and courtesy light (main cabin and luggage compartment - this is an LED festoon bulb): ![]() The dash photo is the only one that seems to do justice to the actual lighting. I hope this helps! Peter Found the bulb orders: Dash LED bulbs: 74-CWHP3 Cool White *IIRC, I added solder to LED connection pads to make bulb holder electrical contact. Courtesy Light Festoons: 6451 LED Bulb Engine Compartment bulb: 67 LED Bulb
1968 912 Coupe ‘Rusty’ 1968 912 SW Targa ‘BOAT’ (Bust Out Another Thousand) 1986 951 2013 Cayenne Diesel Last edited by Peter Graham; 11-10-2020 at 06:59 AM.. Reason: LED p/n's added |
Thanks Peter, ill try Ace hardware for the tape..
Super Moderator
regarding the dimmable option, i found on long drives through dark roads if the dash light is too bright it messes up your night vision, so it's helpful to be able to dim the dash for those situations. heard this was a long-haul trucker's trick and found it works.
I was wrong (again): checking the specs, the dash lights are dimmable; they just don't dim that much (but still might make a difference on a long night drive). Here's a side-by-side comparison photo; fully dimmed left, fully bright right:
1968 912 Coupe ‘Rusty’ 1968 912 SW Targa ‘BOAT’ (Bust Out Another Thousand) 1986 951 2013 Cayenne Diesel |
I bought this kit from somewhere else and it was only $29. But looks like they are no longer in business. And I think I actually used Acetone to clean the old stuff off!!! Just need to wipe in one dir quickly.
Reflective stuff kit Mike G. |
1970's porsche techonology! Lol! mine look like a match in a deep dark cave thats going out. LOL! Once I get some time off, hopefully they will keep me out of the dark..
Maybe take a look at the wiring connections at your headlights. Apparently they are on the same circuit.
Thread Tools | |
Rate This Thread | |
