You really need to simplify things in order to isolate the problem. Jumper out the KLR, Airbag, DME relay, and alarm. Then see if you have spark/injector pulse. Happy holidays! |
When I bought a similar intermittent start/stop 944 it turned out to be a bad wire from the battery positive to the fuse box. The wire had actually melted inside from being shorted out (snow/water sliding off the windshield) moving the wire bundle around by hand resulted in shutting off the running car.
You going to do the bell housing mod? Then you can set the ref spacing with a feeler gauge before sliding the bell housing on. |
I haven't heard of this bell housing mod. Do you have a link? |
It's just cutting or grinding out the two holes the sensors drop through in the housing. Then the housing can slide on/off without moving the sensors. Here's a pic. Some don't like the idea of it. It's your call.
https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/457162-my-new-944-reference-sensor-dillema-need-some-advice-porsche-gurus.html#post4484084 |
About 8 hours to remove the exhaust and get the clutch housing off. Rusty exhaust, wastegate bolts and clutch fork pin were the worst. Unfortunately I had to break the sensor bracket to get the housing off. That lower caps screw would not loosen. I even tried spot welding a 6mm hex socket to it. The pressure plate looks OE and I'll bet the friction disk is toast. Once I get those and the flywheel off, I should have good access to that caps screw. Oddly, this 951 has Lindsey solid motor mounts which are helpful in that you don't have to support the engine with the torque tube off. But, those won't allow you to tip the engine backwards to assist removing the clutch cover. That is really tight. I'm considering a Stage 1 clutch kit but haven't decided on the OE steel flywheel or aluminum. I love the aluminum flywheels but the one I installed on my '87 924S had a smaller dimension so getting the reference trigger pin length set proved to be troublesome.
http://forums.pelicanparts.com/uploa...1640616351.jpg |
i've heard of the risk of of an aluminum flywheel shattering (serious injury!) so unless you're going to install a scatter shield i would keep the stock flywheel and go with the tried-and-true aluminum KEP pressure plate and 930 clutch disk:
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/260928-clutch-r-r-waterpumper-porn.html |
Removed the clutch and as expected, it will be replaced. The rear main seal is leaking as well. With good access I was able to loosen that 6mm caps screw with the bracket stump. The OE flywheel friction surface looks good. I'll most likely re-use that with a SPEC Stage 1 clutch. But when I was cleaning up the clutch housing I discovered that it's apparently a NA part. The flywheel is definitely a 951 part however. I also noted that the flywheel has 3 pins.
http://forums.pelicanparts.com/uploa...1641093871.jpg http://forums.pelicanparts.com/uploa...1641093871.jpg http://forums.pelicanparts.com/uploa...1641093871.jpg http://forums.pelicanparts.com/uploa...1641093871.jpg |
Interesting, will you be resurfacing the flywheel? That third flywheel pin was for the diagnostic port.
I'm following along because I'll be doing a clutch with my son on his new to him '87 turbo soon. |
I get the pin for the diagnostic port but what about the two pins that are in the same plane? That wouldn't be for the reference sensor? I've got an early 944 flywheel and that just has a single pin. Good news is the clutch fork is the correct turbo part but the fork pin will need to be replaced. Note the indentations from the failing needle bearings. An earlier parts order included the shifter bushings so I was looking at that. A PO had tried to make a short shifter on the turbo car by cutting of about 3". So I grabbed the shifter from my '83 944 parts car which was missing the shift rod pin, ground the welds down and moved the pin to the correct length shifter. http://forums.pelicanparts.com/uploa...1641232087.jpg http://forums.pelicanparts.com/uploa...1641232087.jpg |
any reason why you're not going with the KEP pressure plate?
https://forums.pelicanparts.com/uplo...1137267541.jpg |
that clutch fork needle bearing failure is common, a good solution is to use self-lubricating brass bearings which blaszak can modify for you, he also off-sets the center of the hole for the pin to make the fork stronger and compensate for the worn out fingers where the center bearing contacts and wears out the fork, so you can re-use your old fork and get more life out of it.
seeing as how you're capable of doing your own machine work maybe you can do this yourself? https://forums.pelicanparts.com/uplo...1640734298.jpg |
Have you double checked your speed and reference sensors? Switched them?
The drive train is on hold until I get the funds for clutch and exhaust.
But today I decided to do something about the sill cover fitment. I reconditioned both sides front and rear several months ago. Sun and time has shrunk those covers and both sides no longer would mate properly front to back. So I fabricated patches to join those as the ends were dangling. Cut two 3" x 6" pieces sheet metal. make a smooth bend to match the sill cover contour. Make a sharp bent top and bottom for lips to capture the rubber sill covers. Wire brush, clean and paint with self-etching primer. I overlapped the rear cover 4" because the drivers side rear cover was missing a sizeable chunk near the joining end. Carefully drill 1/8" holes with the patch in place and rivet with 1/8" pop rivets with backing washers. Note that the rear cover has a rib about 2/3 up so the top hole needs to be a little lower. I'll paint with Trim Black to match the rubber at a later date. With these I was able to eliminate the troublesome rear body brackets on the front covers. I tried bending those several different ways and was never able to get a tight fit to the sill. http://forums.pelicanparts.com/uploa...1644688628.jpg http://forums.pelicanparts.com/uploa...1644688628.jpg http://forums.pelicanparts.com/uploa...1644688628.jpg http://forums.pelicanparts.com/uploa...1644688628.jpg |
because they hang lower than the bottom of the car, those sill covers get scraped a lot (speed bumps, etc.) so i'd be surprised if they don't get dented up with the abuse.
The windshield on this 951 had a crack along the bottom and the seal was poorly fitted. So I move the decent windshield from my '83 944 parts car to this one. I'll wait until I get a new seal before I glue it in. The fit isn't too bad with a little extra space on the A pillars. I also had to clean up the DS windshield support. That was filled up with sealant and gunk so it wouldn't adjust.
http://forums.pelicanparts.com/uploa...1645729981.jpg http://forums.pelicanparts.com/uploa...1645729981.jpg |
| All times are GMT -8. The time now is 10:30 AM. |
