944 addict
Magic Jack jack points
I recently bought a Quickjack 5000 for easier access to my undersides. After reviewing the recommended jack points diagram, does anyone have any pertinent info regarding jacking the car up with this system? It looks to me like the jack rails need to be from rear pads to the inner support rails. Is this correct or is there more info out there from someone who has used this system successfully?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Last edited by mytrplseven; 01-21-2022 at 01:19 PM.. |
Next time I’m down in FL, I’ll bring my little Harbor Freight Jack, and we can swap. HF Jack is best used on the frame rail.
![]() Sorry. Couldn’t resist. I’d love to have a Magic Jack! So jealous.
‘86 Porsche 951 '69 Ford F100 '83 GL650 rat bike '17 F150 |
Super Moderator
i posted in the faq thread but will copy here for posterity:
if the magic jack is like the 'quickjack' which is basically two platforms that lift the vehicle along each side, it will damage the plastic body side skirts because they hang lower than the 951 frame - i learned this the hard way when a tire shop used them many years ago. it looks like it comes with some type of rubber blocks to contact the lift points, as long as those line up to contact the correct lift points and provide enough clearance so the side skirts don't touch the jack platform you should be okay. image for clarity.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) Last edited by nize; 01-22-2022 at 09:41 AM.. |
944 addict
I can't believe I used the wrong name. It IS the quick jack 5000. The advertisement says it's proper one for Porsches but may not have considered the 944. Looking for guidance here. It has rubber blocks that stacked can get up to 4 inches of penetration. As such the car can be lifted up to 23 inches with mechanical locks on the rails. Takes about 30 minutes to hook up the power unit and raise the car.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Last edited by mytrplseven; 01-21-2022 at 01:24 PM.. |
Super Moderator
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
I finally got the 5000 late last year. It does take a while to get set-up, but lifts both sides at same time with no running around with jacks, ramps or stands. Really is great when you need to lower and raise up again. For the 951, I angled it in at front to catch the frame rails. Just be sure to be clear of the side skirts. Also, works great for my Vette.
944 addict
Doing one side at a time is torquing the body and is a pain. Plus I can raise it up to nearly 24 inches. Well worth the speedy operation and no jack stands needed.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Not a problem. The upper part is one piece and does move....forward or back depending on orientation to vehicle. Raise Quickjack to point where lifting blocks are nearly in contact with vehicle lift points to check alignment before proceeding with lift.
Super Moderator
944 addict
They actually do lift straight up. Once they are all in contact with the jack points, they don't move.
Kessel run in 12 parsecs!
I think I have the smaller quick jack, my car is longer than the top surface, Im worried I will end up in a floor pan and it might tear it up. So I just use my magic jack as a cycle lift. LOL!!!
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
Super Moderator
https://youtu.be/iWC0gWLWaDY?t=40 if the two jacks are not parallel to each other, the contact points will change between the up/down positions. i've attached my highly technical diagrams that explain this: side view: ![]() top view:
