-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   What is this and where does it go (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/1115143-what-where-does-go.html)
mscromer 03-20-2022 05:09 AM
this is on a 86 turbo engine harness that caught fire. what plug is this and where does it go. Thanks
http://forums.pelicanparts.com/uploa...1647781627.JPG
huskerick1 03-20-2022 05:32 AM
Looks like one of two resistors for the cooling fan, located on the firewall next to the battery.
The aluminum base must have melted away.
mscromer 03-20-2022 06:07 AM
Thanks. I checked and that’s not it. What ever this is it is located in the engine bay somewhere.
nize 03-21-2022 08:03 AM
can you be more specific in which area of the engine bay it was found?
mscromer 03-22-2022 10:48 AM
Sorry I would if I could have but I got this car with the entire intake system taken apart. I did finally find out it is the wastegate cycling valve. A heavily burnt one I might add. Lol
Fast Freddy 944 03-25-2022 05:36 AM
Dude, good luck, you should have walked away from a burnt car. You might want to take it to a restoration shop and bite the cost bullet. If it's burnt it might be un-recognizable. There is a place that restores Classic Porsches, called Mayo Porsche in mid cities dfw, just tow it there....
notny41 04-12-2022 06:00 AM
I agree - definitely looks like one of the two cooling fan resistors. They are located on the firewall kind of by where the battery is if I recall. (still in the engine bay)
nize 04-12-2022 11:22 AM
i don't think that's the cycle valve because the cycle valve is made of plastic and sits on top of the engine, it would be completely melted in an engine fire. the off-set electrical connection does make it resemble a CV though. here's what the cycle valve looks like:
https://cdn1.pelicanparts.com/catalo...17-00-M100.jpg
listed here on pelican:
https://www.pelicanparts.com/More_Info/95160611700.htm?pn=951-606-117-00-M100&bt=Y&fs=0&SVSVSI=1026
