LinkBack | Thread Tools | Rate Thread |
Pelican Parts Vendor
New CSF Porsche 944 (NA & Turbo) High Performance Radiator + Fan & Shroud Kit
CSF worked closely Joe Anselmo Motorsports in development and is pleased to release the High-Performance All Aluminum Radiator (CSF #7088) + Fan & Shroud Kit (CSF #8180) for the Porsche 944 (NA & Turbo).
![]() ![]() Design & Engineering Joe Anselmo Motorsports is one of the leading Porsche service centers here in Southern California and specializes in 944s. With Joe’s knowledge and expertise, CSF was able to design the radiator to fit all models of the Porsche 944. This High-Performance Radiator is a True Plug-and-Play “Drop-in Fit” upgrade. ![]() ![]() All mounting brackets are CNC Machined for precise fitment. The cooling inlet/outlet connections use the same OEM style slip on connection type for use with any OEM or Aftermarket radiator hoses. How it fits NA & Turbo Many 944 owners know that the OEM Radiators for the NA and Turbo aren’t normally cross compatible without modifications. This is due the OEM Turbo radiator being ~1 inch taller than the NA version. While designing the radiator, CSF decided to base the dimension off of the NA radiator while increasing the core capacity to still exceed the OEM Turbo radiator’s cooling capacity. Using a 2-Row 42mm core with CSF’s Exclusive B-Tube Technology, the size difference is not a limiting factor in cooling performance. To remedy the size differential for installation, CSF includes CNC Billet spacers for use on the 944 Turbo (AKA 951). Attention to Detail CSF also included removable/adjustable crossover pipe brackets on the top of the radiator. The 944 Turbo model’s have a crossover cooling pipe while the NA version does not. This pipe is designed to distribute coolant from the reservoir to the radiator and from the coolant pump house to the cylinder head. From the factory, this pipe is normally zip tied to the top of the radiator to keep it from rattling around. Joe Anselmo thought this was a great addition to the radiator making the installation feel better than it came from the factory. Upgrading the Fans While the OEM Fans are functional, they are still a design dating back to the 1980’s and leave plenty of room for improvement. Electric fan technology has progressed a lot over the years and newer fans can efficiently move more air with a lower drawn on your car’s electrical system. The laser cut shroud ensures the most efficient function of the fans drawing air through the radiator. The low profile dual 9-inch SPAL fans move 1180 CFM of air. The Fan & Shroud kit is designed to fit the CSF #7088 Radiator but will also fit OEM 944 NA Radiators. These fans have standard SPAL connectors but can be rewired for OEM connectors during installation. Many 944 owners know that the OEM Radiators for the NA and Turbo aren’t normally cross compatible without modifications. This is due the OEM Turbo radiator being ~1 inch taller than the NA version. While designing the radiator, CSF decided to base the dimension off of the NA radiator while increasing the core capacity to still exceed the OEM Turbo radiator’s cooling capacity. Using a 2-Row 42mm core with CSF’s Exclusive B-Tube Technology, the size difference is not a limiting factor in cooling performance. To remedy the size differential for installation, CSF includes CNC Billet spacers for use on the 944 Turbo (AKA 951). ![]() ![]() ![]() Porsche 944 (NA & Turbo) High-Performance All Aluminum Radiator & Fan + Shroud Kit Features (CSF #7088 & #8180) #7088 – High-Performance All Aluminum Radiator
#8180 – Fan + Shroud Kit
Where To Buy: Available from Pelican Parts
Ultimate Performance Cooling Last edited by CSF Cooling; 04-04-2023 at 04:27 PM.. |
Kessel run in 12 parsecs!
Cool!
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
very cool! love the custom shroud and spal fans
2002 Porsche 911 turbo 2007 Porsche Cayman S track car 1987 Porsche 924 Carrera GT tribute 2015 BMW X5 |
Super Moderator
very nice and much needed product!
thanks for making this plug-and-play solution available.i'm curious why it was painted black instead of keeping the aluminum visible? wouldn't the black paint act as an insulation while bare aluminum would transfer heat better for improved cooling?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
