Engine cut out with quick throttle opening
Whenever I press the throttle quickly, trying to get to WOT the engine cuts out, meaning the car bucks and stops accelerating like the fuel has been turned off momentarily to all 4 cylinders. Or like the air/fuel isn't right.
However, if I lead the throttle and don't smash it, it can rev to redline and build boost.
Anyone got any thoughts on what to check next?
1986 944 Turbo - Guards Red |
In the Fires of Hell.....
Is this stock with stock chips and no boost enhancer?
I would have gone with a vacuum leak, but it looks like you have that sorted out. Check your fuel pressure at the rail and see if it's low. I have had what you describe happen on mine when it's cold, but not when the engine has warmed up. Last item I can think of right now: What plugs are you using?
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
I installed a new FPR and damper to no affect. Plug, I don’t remember but they have less than 3000 miles on them.
