Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Found this orifice in vacuum line???
Found this small aluminum plug with a hole through it inside vacuum line to Venturi. Anybody know what this is or if it even should be there?
Old 06-25-2023, 06:34 AM
In the Fires of Hell.....
kdjones2000's Avatar
Sounds like an '86. Many people do a "Venturi Delete" on their cars, and Porsche removed the venturi on later cars.
Not sure if that aluminum part should be there or not, however.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-25-2023, 12:13 PM
soxnail's Avatar
Looks like a home made restricter....
I did the venturi delete long time ago, no aluminum pieces in there.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 06-29-2023, 08:51 AM
Super Moderator
nize's Avatar
i agree with sox, it looks like a home made restrictor. you should do the venturi delete.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 07-05-2023, 01:45 PM
