I just bought the 2023 Lindsey Racing MAF kit
Hello Porsche Friend's
I wanted to share that I recently acquired the LR MAF kit for my 951 just last month through Dave, and I must say, the installation was a breeze, and it works perfectly. Now, let's talk about the 2023 kit; it's been redesigned to be even more user-friendly. My ride is an '87 951 Street only with just 79k miles on the clock and impressive 140 compression across all cylinders. I've also got 6% leak down numbers. As for my setup, I'm rocking the dual-port wastegate with an MBC, set to a comfortable 15 psi boost. I've also installed the LR AFPR, maintaining a steady 44 psi. To top it off, I've got the KKK 27.8 Turbo with a FabSpeed full 3 exhaust system with 200 cell cat in there. The gas in my area is 93 oct. The results? A smooth idle and seamless acceleration all the way to full boost. With my FQS set at 0, I'm getting 14.5 to 15 at idle and cruise, and a safe 12.0 at full boost in third and fourth gears. Considering the cooler DC temperatures at around 70 degrees, it's just right. Now, for those scorching hot months, I'm planning to switch the FQS to #1. This setting gives me 11.8 at full boost and 14.5 to 14.7 during cruising. I tested this setup myself last week when the temperatures hit the 90s. I couldn't be happier with how it's performing. Love it! Helio
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo Last edited by heliolps2; 09-28-2023 at 09:51 AM.. Reason: Title change |
Sounds like it fits your car perfect will you Dyno your setup? Also from when you ordered until received package from Lindsey how long did that take?
Helio
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Both cars in the Pictures look Great I have a 911 G50 87 cabrio and a 944 Turbo 89 Love both but I still enjoy the 944 for long trips, nothing much to it the car has a SS exhaust and a Lindey chip with 3 bar fuel regulator, maybe I should try and buy the LR MAF kit I wonder what is the benefit? smoother? more HP? let me know take care
