Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
In Vino Veritas
Dash Lights Suddenly Out
Hello, all!
The dash lights on my '87 Turbo have suddenly gone out. I figured it was the fuse--but it isn't blown. This appears to only be the actual gauge lights, as the assorted idiot lights still work as expected.
Is there something obvious that I am missing here? It's a PITA driving with a dark dash....
Thanks in advance for any suggestions.
Todd
Old 02-10-2024, 10:08 AM
soxnail's Avatar
You probably have dirty or loose connectors in the instrument panel. Open and take of the 3 connectors CAREFULLY!! they are fragile with age. Clean the edges with alcohol and a a soft brush, like an old toothbrush. Re plug and should be fixed.
BTW the lights that illuminate the dash are the 3 at the bottom feeding the light guides, and the connector used for the lights is labeled 'C'
Sox
Connectors
Getting the connectors off.
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 02-10-2024, 11:16 AM
It could be that the "light pipes" on the underside of the instrument cluster are no longer funneling light from the bulbs at the back of the cluster to the front. Porsche (actually VDO) used a silver paint as a reflective medium to keep the light in the funnel, and over the years the paint has deteriorated to the point that it cannnot illuminate the front of the gauges anymore.
The repair is fairly simple: Use non-acetone fingernail polish to remove the rest of the paint (so that you can see clear plastic. Then use two inch aluminum tape to cover the trapezoids on the bottom. Then use an exacto knife or razor blade to remove the excess tape.
Of course, this assumes that you check the bulbs first.
Good luck, George Beuselinck
Old 02-10-2024, 11:19 AM
soxnail's Avatar
If it went out suddenly as he states, then more likely electrical, when my light guides started to fail they slowly dimmed out over time.
Sox
Old 02-10-2024, 11:38 AM
In Vino Veritas
Sox
Connectors
Many thanks--I'll give this a try and report back!
Todd
Old 02-11-2024, 06:22 AM
