Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
car won't start
Car won't start. After reading another post on here, I bypassed the ignition switch by running jumper wire from a ignition connector to starter near the firewall. Ran a wire from the red lead on the connector to the battery and it fired right up. Still using the key will not work. Is there a way to test the solenoid on the starter to see if it is bad?
Old 09-03-2024, 04:24 AM
In the Fires of Hell.....
kdjones2000's Avatar
Likely your ignition switch died...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-03-2024, 06:14 AM
