Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
soxnail's Avatar
Question Rear Wheel Bearings
*edit 10/31/2024 by nize as requested by the original author soxnail*
*a direct link to the complete write up is here:
https://forums.pelicanparts.com/porsche-944-turbo-turbo-s/337037-rear-wheel-bearings-3.html
Well its that time, I have to replace the rear wheel bearings. I have never done these before, but I don't want to go to the Porsche shop. So far the wiser and more experienced people on this board what am I looking at.. I know that getting the big nut off and pulling the bearing is the main thing any help hints and pitfalls info would be welcome .
tia Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 03-21-2007, 09:16 PM
winter-hater club member
nynor's Avatar
check out arnnworx.com. bruce has some tools specifically for this job. he also has a complete write up.
"COOL PRIUS!" - Nobody Ever
Old 03-21-2007, 09:50 PM
nynor's Avatar
http://arnnworx.com/RearBearings.htm
Old 03-21-2007, 09:51 PM
soxnail's Avatar
Thanks Nynor for the quick reply. will check it out.
Sox
Old 03-21-2007, 09:52 PM
soxnail's Avatar
Well I did get the tool from arnnworx, thanks Nynor. I just got to working on the bearings today (stuff came up).
Any way broke an 1/2 inch breaker bar no kidding ! see pic. So will take it to a tire shop that has bigger tools..
Sox
Old 04-14-2007, 03:16 PM
nynor's Avatar
holy cow!
i see you also had the special P-TEE tool on hand.
Old 04-14-2007, 04:32 PM
soxnail's Avatar
Yup cant do without the pee-tee tool
Cant find a shop that will loosen up the axel nuts for me, all say its a liability problem will try an "independent " shop tomorrow.
Sox
Old 04-14-2007, 05:59 PM
nynor's Avatar
are you planning on driving it after loosening them?!?
i'd go to sears and buy a 3/4" breaker bar and socket...
Old 04-14-2007, 07:48 PM
soxnail's Avatar
I was going to get them to loosen it and then just tighten it to 150 or 200, and drive home very carefully. Just bought a $28 socket and it is 1/2 inch drive. I would think that it would be strong enough. Just need a better breaker bar
Old 04-14-2007, 07:53 PM
nynor's Avatar
i got a craftsman breaker bar. its pretty stout.
Old 04-14-2007, 08:19 PM
soxnail's Avatar
Thanks...I have one its 18 inches long so...
to get about 700 ft/lbs with 18 inches I figure I need 466 lbs of force on it. The first one was a pep boy one and it failed when I tried to lift it up. I can lift a lot more( 475 lbs dead lift) than what I can put on it which is my weight (202 lbs).
T=F x D where T is torque in ft/lbs, F is force in lbs and D is the distance from the torque application point.
rearranging the formula F=T/D
put in the values D= 18 inches or 1.5 ft, T= aprox 700 ft/lbs
we get F=700/1.5 or F=466 lbs
So it should work.
QED
Sox
Old 04-14-2007, 08:34 PM
nynor's Avatar
700lbs? i thought those babies were at approximately 300 ft lbs... don't hurt yourself!
Old 04-14-2007, 08:59 PM
soxnail's Avatar
well that is for new unrusted nuts with age an rust the force needed can be as much as double..
I have already bust some knuckles on the last breaker bar the went kaput. I will be a lot more cautious this time
Old 04-14-2007, 09:06 PM
soxnail's Avatar
Ok time to try some thing else
see pic
Sox
Old 04-14-2007, 09:45 PM
nynor's Avatar
um... wow. that looks dangerous!
who made the wrench? i'd really try a craftsman. failing that, i'd get a 3/4" breaker bar and a socket to fit it.
Old 04-15-2007, 03:16 PM
soxnail's Avatar
that was a craftsman..they gave me my money back. Will get a 3/4 set next and continue to try and not hurt any thing essential
Old 04-15-2007, 05:13 PM
nynor's Avatar
all right then. we really need to meet over beers sometime. anyone that can break two of those... well, i don't know what else to say.
Old 04-15-2007, 05:45 PM
soxnail's Avatar
be fun bring bananas (for the gorilla)
If you are down in Dallas I will definitely be up for the brews.
Sox
Old 04-15-2007, 05:50 PM
soxnail's Avatar
Ok got the silly nuts off..3/4 breaker and 3 ft of bar. Now how do I get the hub off Clark's web site says use a drift and a hammer from the back (arm side). Arnnworx site says use a slide hammer. I cant seem to get either to work I don't want to mess up the hub..any help be appreciated
Tia Sox
Old 04-16-2007, 07:28 PM
nynor's Avatar
maybe pictures of what you have going on would help.
Old 04-17-2007, 10:59 AM
