Sunroof for 944
Greetings ... I have a 85.5 944 NA with 3 position ignition switch. The sunroof opens and closes fine regardless of ignition switch position (1 or 2) ... but won't retract (to allow roof removal) in any ignition switch position. I've checked the fuse and relays - all look like working good. I've followed clark's garage and yet still no retract ... any suggestions?
BTW - big thanks to the forum ... being a new 944 owner, the information I find in forum is invaluable. LMK - Cheers |
One of the microswitches is not allowing the arms to retract.
Good luck, George Beuselinck |
Super Moderator
troubleshooting details on clark's garage:
https://www.clarks-garage.com/shop-manual/elect-18.htm
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
I just fixed the same thing. The switch that is furthest from the motor on the slide. (nearest to the back of the car).
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Sox
