Wheel caps
The other day someone decided that needed one wheel cap from my car....came back from store to the parking lot and it was gone.
I would like to replace it, but don't want to drop 500 plus bucks on them right now. Any other options ? Wheels are option 395 16" Fuchs forged alloy wheels. Outer dia is about 80mm and the hole in the center of the wheel is 71mm. Thanks Sox ![]() ![]()
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
The newest of the noobs!
I'm missing one on my '89 car, and check FB Marketplace periodically.
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
Super Moderator
$62 on amazon
https://www.amazon.com/993-361-303-10-9A1-1999-2005-Porsche-911-Center/dp/B00DJ6C8UM Also $63 here on Pelican: https://www.pelicanparts.com/search/?q=993-361-303-10-9A1
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Thanks Nize, the amazon link does not go any where...
The Pelican one is silver, mine are black but could switch to silver. Sox
Nize fitment???
Thanks Sox ![]()
Super Moderator
blah. what is the part number? try searching using that.
"Blah" is that your technical opinion on the accuracy of the fitment comment from Pelican ?
![]() Have tried to find a part # but the PET is silent on the subject. The part # is 911 361 032 28 or 911 361 032 29 not certain. Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC Last edited by soxnail; 06-09-2025 at 07:31 AM.. |
This one won’t work, but any ring one from Fuchs will work, later on I will pull out one of each to show you the difference
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Ok, here you go
![]() ![]() There is one more type, looks like the one you have, but it has 3 prongs instead of the ring, for early Fuchs
Yup the one in the middle looks just like mine, except for the color mine is silver all around. See pic above and of course has a ring rather then prongs.
Sox
You need the one on the left, fortunately, they are very common, do a search on the 911 parts for sale, Fuchs center caps and multiple sets or singles should pop up.
Thanks Byron,
BTW that's an impressive number of posts. Sox
