Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
larry_s's Avatar
951 odometer
how do i remove the odometer needle so that i can replace my trip odometer gear??
86 951 blk/blk
Old 07-29-2003, 08:37 AM
I think you mean the speedometer needle? It takes a little bit of effort and patience. You have to sorta pull on it pretty hard and wedge it off by rocking it back and forth. The key is to be try to loosen (requires a good pull) it off of the little thing holding it while being gentle enough not to break the thing holding it. Make sure you put it back on with it exactly at 0 or else you could be going 5-10 mph over or under what speed you think you're going at.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 07-29-2003, 09:35 AM
larry_s's Avatar
Swim thanks, i had to change my odometer gear but managed to get arouond not taking off the needle, but i want to go to the white face plates and need to know how to remove them without breaking them
86 951 blk/blk, Auto Authority chips, wastegate shimmed , Weltmiester springs (lowered 1 1/2") , koni shocks and struts, 17" Turbo rims, 3" exhaust with hi flo cat and borla freeflow muffler.
Old 07-31-2003, 08:49 AM
