Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
ICD ICD is online now
How big of a deal is Limited Slip
I know this sounds like a dumb question, but here goes:
I'm looking at buying an 944 S2, and the owner said it had limited slip. The PPI determined it did not have LSD (owner could not find the codes in the trunk). Everything else checked out great, but now I'm trying to decide whether or not to go through with the purchase.
Soooo...am I going to miss LSD? How big of a deal is it with these cars? Should I go through with the deal?
Old 11-18-2003, 03:29 PM
On an S2 I wouldnt think its a big deal, but on a modified turbo, it really helps to put the power to the pavement.
1988 951 Alpine White / Burgandy
Profec B spec II EBC,HomeBrew Chips, WideFire HG, Tial 38mm, Magnecor Wires, Koni Rears, Adj Rear Droplinks, Zeitronix WideBand.
Old 11-18-2003, 06:07 PM
That would be my advice too.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 11-19-2003, 03:53 AM
Ebs Ebs is offline
I've driven Camaros that just spin the wheels in first gear (automatic gearbox with no brake toquing, just full throttle application) because there is no LSD. If the car puts the power down well I woudn't worry, that said I've never driven an S2.
1986 951 Euro spec model
Anthracite on black
105,000 km
K&N, Lindsey Boost Enhancer, chipped, oversize fuel regulator
968 Club Sport anti sway bars
Adjustable Koni Yellows
Fuchs alloy : 9 inch rear, 7 inch front
2.5 inch stainless steel exhaust
1984 928 S2 (Jap spec)
1977 Mazda 323 - hard core tuned
Old 11-19-2003, 06:27 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Yup I agree with has been said as well.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-19-2003, 07:46 AM
andrewgoh's Avatar
I have an 84 944 NA with LSD, but not on my 86 951. Can I insall the LSD unit from the NA to the 951?
Old 11-20-2003, 09:38 PM
Correct me if I'm wrong, but with an open differential you would just spin one wheel and do a one-wheeled burnout. That's the purpose of lockers for offroad applications, to keep both wheels churning instead of just one.
FWIW I don't think any Camaro/Firebirds (at least the V8 powered ones) came with open diffs, pretty sure they all have LSDs.
Old 11-24-2003, 09:00 AM
1.2gees's Avatar
Send a message via AIM to 1.2gees
andrewgoh, it's not a good idea to swap the two diffs, as the turbo unit needs to be alot beefier (and the factory ones are).
Joe Anstett, your assumption would be correct on a lot of cars. In a straight line my 944 t will spin both the tires. If your suspension is fairly tight, you shouldn't have too big of a problem spinning the inside tire, around the faster corners (a bigger sway in the front will help a lot, forexample).
Ahmet
Cheers!
Old 11-24-2003, 10:24 PM
andrewgoh's Avatar
1.2gees, thanks for the advice. Good call on the 951 being a "beefier" tranny and not wise to swap LSDs on the trannies.
Old 11-25-2003, 12:08 AM
1.2gees's Avatar
I actually don't even know if it would fit, but the point remains...
I'm thinking about trying to find an S2 transaxle w/the LSD, as it's pretty much a waste of time to try to find a turbo transaxle w/the LSD for less than $1k.
Ahmet
Cheers!
Old 11-25-2003, 01:42 AM
Techmonkey's Avatar
On my current 83 it doesnt have LSD.
On my old just burrned 83 it had LSD.
both N/A's
I have tested one car after another on my semi-country paved road I have pushed both to the limit around an intersection. I feel the car with out LSD slipping with one tire(as well as hearing it spin) where the other pulls through the corner harder without slipping.
83 944 with 87 engine 5-speed LSD
burnned
Old 12-02-2003, 01:13 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
yeah, i think that my old car w/ out lsd was sometimes better than the one w/ it, but it seems much easier to control the spinning in the lsd car. I wouldn't say at least in my car that lsd is really that big of a deal. Maybe on a car w/ greater power
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 12-14-2003, 02:51 PM
J1NX3D's Avatar
http://members.rennlist.com/emcon5/velocity_lsd.pdf
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 12-19-2003, 05:59 PM
bogomili's Avatar
I love my LSD in the snow
Old 01-02-2004, 08:52 PM
1.2gees's Avatar
Well, I finally found what appears to be a turbo cup transaxle (anybody who can help me w/the transaxle codes, feel free to chime in). I shall update this thread later in the week!
Ahmet
Cheers!
Old 01-03-2004, 02:30 AM
1.2gees's Avatar
So I have finally gotten a chanse to toss around my turbo w/a LSD in it. My first impressions were that it's a lot easier to break traction in the rear, but a lot more controllable. After living w/it for a few days I must say that it's nice to have if you can drive with it. It does let you apply more power down, but I feel like it's happiest when the car's oversteering at about a 5 degree angle. I'm going to have to videotape things again now. Lots of fun!
Ahmet
Cheers!
Old 01-05-2004, 01:22 PM
ae1969's Avatar
... I received mine this week as well (LSD)..... its sitting in a crate in my garage. I can't wait to break the tires loose as well.
Old 01-05-2004, 01:41 PM
entertaining the idea
UconnTim97's Avatar
I definitely enjoy the LSD in my car...Best handeling car I've ver driven
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 01-05-2004, 08:23 PM
