What is the best fuel pump to get?
My problem is my fuel pressure drops off at high rpms.. I have replaced the fuel filter after the pump and checked the filter before the pump. I also check the voltage at the pump. So my next thought was to replace the pump..
Is there a better pump than the stock pump... TIA Marshall |
This could actually be a voltage regulator problem too since the fuel-pump has no idea what RPM your engine is running at, but the alternator does. Monitor the voltage AT the pump itself and see if that goes down with RPM.
Also check your FPR, many of the adjustable have short lives. |
