Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Kirby2's Avatar
Turbo Upgrade
I am in touch with a turbo shop (MJM Turbos) about upgrading the original K26 turbo to the larger K27 (new impellers and housings.
Has anyone done this?
Is the upgrade worth the $$ ?
Has anyone dealt with this vendor?
Help!
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 02-11-2004, 07:46 AM
Black 951's Avatar
Check out this site it talks about the ups and downs to putting a bigger turbocharger on your car.
www.clarks-garage.com/951faq.htm
good luck!
Old 02-11-2004, 10:29 AM
ae1969's Avatar
Send a message via ICQ to ae1969
K27/6 is a great combo you can get 300rwhp from it...
You will need new chips for it as well, and a MAF would be ideal.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-11-2004, 02:01 PM
I just tuned a car with K27/8@20psi with APE-MAF and 50# injectors. Got 362rwhp!
Old 02-12-2004, 01:56 AM
DannoXYZ,
What octante fuel do you put in it to run that kind of boost?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-12-2004, 04:32 AM
1.2gees's Avatar
Send a message via AIM to 1.2gees
I would go for a K27/8 (like what Danno is running) before going to a K27-6.
Ahmet
Cheers!
Old 02-12-2004, 10:47 PM
"What octante fuel do you put in it to run that kind of boost?"
We used a 50/50 mix of 91-oct. pump gas and 100-oct. race-gas. So it's about 96-octane effective. The 2-degree retarded-ignition setting on the chip would have allowed using 91-octane at that boost as well. I'm also currently testing out a K26/6 with wastegate-mod that allows 25-30psi of boost (20psi @ 2500rpm). The key to tuning these things is being able to adjust timing in minute increments. Sometimes, I make adjustments in just 1/3rd of a degree.
Old 02-12-2004, 10:56 PM
