83' 944
My 83 944 Has No compression in 2 chambers, the mechanic said it was a compression seal but ive never heard of that. i want to know if its the head gasket that i should replace or what possible seal it could be.
Sounds like a possible head gasket, ring or head/block issue. I would check the compression on each cylinder without the plugs. Next check the compression "wet" ( add a small mount of oil to cylinder) if the weak cylinder improves with the "wet " test it is piston or ring related. If the compression does not improve it is upper end related. I would then pull the head and inspect gasket surface and valve train. How is the timing belt, i would suggest pulling the cover and checking the timing marks if off by more than 2 teeth its going to have to come apart anyway !!
autowerks9 PCA SINCE 1991, REISENTOTER 1982 EURO 928S 320HP MEDIORMETALIC/BURG. 1987 944S- GT3 BODY CONVErSION RED/BLACK( sold ) 2003 MERCEDES E500 Sport "Einfarbig" |
