Pics of my car
[img]http:/ I finaly figured out how to do this. The guy wanted $7000 for it. He said the cluch was bad so I offered him 6 and he took it. Brought it home and re adjusted the peddle and it worked fine. It also has a new head, water pump radiator and intrecooler. The leather is in great shape and it still has the original dash. It dose need some fog lights though.What do you think?
86 951 Black on Black Konis Yellow front, Orange back Fast as hell 87 944 na 66 Skylark ( in parts ) 750 Honda Chopper (8 ' Looong) 800 Vulcan 02 Grand Prix GTP ( Wifes Car) also Fast as Hell |
Looks great! How many miles, and where are the foglights?
...sick with gearheadia |
Miles show 112000 but of course the odometer is broke. I have the gear and white gauge faces to put in when I get around to it. The fog lights were gone when I bought it, thinking about putting some black plexiglass in there place to cover the holes until I can find some for cheap.
vott does ziss do?
get the belts changed immediately if you don't have any proof that they were done in the last 30k or so. also, since the odometer is broken, you have no way of knowing the actual miles on the car, making it quite difficult for anyone to prove that the belts were done recently. as for the clutch, if it is the original clutch, it is probably on its way out no matter whether you were able to adjust it or not. sooner or later, the center disc will fail
you hould be able to find new replacement fog lights for about $130.00 each or so
Is the paint original?
Also missing an undertray under the bumper (I bet it's missing the two under the engine as well). Seems like a good buy otherwise. Ahmet
Cheers! |
I already changed the belts and all vac hoses. Since it has a new head on it I figured it has shucked a belt already.
The paint is not original but, it's not a bad job.
