Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
larry_s's Avatar
Porsche Crest Distributer noise
Ok i found that my noise problem seems to be comming from my distributer, sounds like metal on metal slapping. any ideas on what this is and what could have caused it?
86 951 blk/blk, Auto Authority chips, wastegate shimmed , Weltmiester springs (lowered 1 1/2") , koni shocks and struts, 17" Turbo rims, 3" exhaust with hi flo cat and borla freeflow muffler.
Old 05-15-2004, 05:30 PM
hey mines is doing the same thing. i haven't figure it out yet. if you get an answer please let me know.
porsche 928 euro
944 ct
Old 05-17-2004, 05:24 AM
The timing belt is loose. Get it looked at right now!!!!
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-17-2004, 05:32 PM
larry_s's Avatar
If that is the case, wy would it sound like metal slapping, like a lifter slapping, and would it not make the car run bad? the power is fine and so is the smothness??????
Old 05-21-2004, 06:05 PM
I offered an idea on what's wrong with it, that has been my experience based on what little detail you gave. I note that you have not looked at it yet. If it's a abnormal noise get it looked at right now!
Old 05-21-2004, 06:54 PM
larry_s's Avatar
ok i figured it out Britwrench no offence i didnt give you alot of info but a loose timming belt would not have a metal on metal slapping sound.....
so with that in mind i took off the dis. cap and cover and found that the rotor was tearing up my dis. cap becasue the bolt that holds the metal piece that holds the rotor came loose and caused that sound and the damage to the rotor and cap.
STIFEKAT if you have the same sound comming from the distributer cap then that might be the problem, just take the cap off and if the rotor wiggles around and the star bolt is loose,,, welcom to my world... better than spinning a bearing though.
now what the hell is that metal piece called that the rotor mounts to so i can get a new one, there is some wear on mine now
i have photos i can send if i can get a answer...
thanks brit for the suggestions at least you gave some
Old 05-22-2004, 03:31 PM
Actually, a loose timing belt sounds exactly like metal slapping metal, goes away when warm.
Old 05-22-2004, 04:28 PM
larry_s's Avatar
Ok,
Brit do you know the name of the part that i need? it is the piece of metal that the rotor mounts to??
and can it be bought after market or just from a dealer
Old 05-23-2004, 04:59 AM
MINES SOUNDS LIKE metal slapping metal only while starting the car. then i whines down as if somthing just stop spinnging. it cranks fast. and i see oil on the engine block if i stand on the passenger side were the battery is and look down just under the exhasut manifold. i pretty sure mines is a combination of a starter on the way and a headgasket, or intake leak. i'll have to comfirm the intak theroy by looking in the intercooler pipes for oil. but theres a great lose of power.
porsche 928 euro
944 ct
Old 05-24-2004, 07:37 AM
