Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
larry_s's Avatar
Porsche Crest Distributer rotor Glue
I found that my diesel sound was that my cheese head screw that holds the rotor carrier/ camshaft mount had backed off and let the rotor spin off center, trashing it, also the camshaft mount looks like it got screwed up to, both have been ordered,
My question is what type of glue do I use to mount the new rotor to the mount and any recommendations for a bolt lock type material so I don’t have to worry about the cheese head bolt coming lose again.
3rd anyone know what torque setting to tighten the cheese head bolt?
Thanks a million
Larry
Larry
86 951 blk/blk, Auto Authority chips, wastegate shimmed , Weltmiester springs (lowered 1 1/2") , koni shocks and struts, 17" Turbo rims, 3" exhaust with hi flo cat and borla freeflow muffler.
Old 05-29-2004, 07:29 AM
Autobahn Garage
I use removeable Loctite the blue stuf
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 05-29-2004, 08:28 AM
larry_s's Avatar
is that stuff heat resistant????
and do i use that for both the cheese head bolt and to glue the rotor on???
Old 05-29-2004, 09:05 AM
Autobahn Garage
I use it on the screw, and a small drop on the shaft of the rotor. And yes this is heat resistant, but remember there is not alot of heat in that area of the engine anyhow
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 05-29-2004, 11:31 AM
larry_s's Avatar
Tab tanner thanks for the info, i dont sapose you know the torque setting for the cheese head bolt that holds the rotor mount carrier do you???
Old 05-30-2004, 08:06 AM
Autobahn Garage
I'll check the manual and get back to you on this
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 06-01-2004, 11:58 PM
Autobahn Garage
larry_s, Here is the torque specs for you
Camshaft pulley to camshaft bolt / allen=33 serration bolt=48-50
Rotor to shaft =3
All these are in foot pounds
Good luck
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 06-02-2004, 08:41 AM
larry_s's Avatar
thanks for the help and specs i ordered the part from auto atlanta but they never sent it after saying they had it, so after a week i told them to pound sand...
so i guess its retail time and to the local porsche dealer, cause that part is hard to find aftermarket
thanks again
larry
Old 06-08-2004, 04:18 AM
