my coolant resevior is pressurzed as soon as i turn the key. if i start the car for about 2 seconds. and then turn it off and open the cap it piss until coolant bubbles out. . no coolant leaks. i'm thinking its a head gasket. if so i'm mechanicly incline i just do not have a whole lot of major tools such as a lift or airpower tools. how in depth is changing the headgasket on a turbo. its a 1987 turbo. also what should i change while i'm there
porsche 928 euro 944 ct |
0sounds like a headgasket, do a compression test without the plugs and see what you come up with. CHeck the plugs for signs of coolant. Headgaskets are not too hard. 90% is done from the top with normal hand tools. definately have the head checked and inspect the block for expecially for the cylinder in question. might as well do the belts and seals while you are in there. If you are running higher boost concider a wide fire gasket.
autowerks9 PCA SINCE 1991, REISENTOTER 1982 EURO 928S 320HP MEDIORMETALIC/BURG. 1987 944S- GT3 BODY CONVErSION RED/BLACK( sold ) 2003 MERCEDES E500 Sport "Einfarbig" |
Yup head gasket....
PUll the plugs and look in each hole with a flashlight........ it should be pretty obvious. Not the end of the world but your fun is over for a little while.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
thanks alot guys. i'll get my shop manuls out and my tool collection.
How many times can the head studs be touqued. I have been told once and then they should be replaced with with a Raceware type of stud.
'86 951, MAF, K27, 46 tial, 3" ext '84 Audi Coupe '87 Audi 5000 QT (QLCC chip) '89 Merkur Scorpio 5 speed RIP |
HEY S928S what modifcation did you do to your 1982 euro to get 350hp. curious casue i have and 1983 euro.
also me and my friends from the 928 message board r having a mini meet on on the 19th of this monday which is this weekend. were meeting at the oxford valley mall at 2pm. don't know how far that is but from you but we'd love to have you attend. only a group of 3.
of this month (sorry spelling error)
I would love to be there for the meeting on the 19th. but unfortionatly i will Be in Italy. But please let me know of any future gatherings, i am only about 30 min from there. Wife has drained my walet there may-o-times.
the hp is estimated at this point, was hoping to get it dynoed again this spring with the local porsche charity event but missed the chance. now i have to rent a place with my buddies to gey checked. mods: ported and polished intake and runners large volumn fuel pump. incresed diameter to fuel nosels and lines and adjusted fuel management for k-jetronic remove air pump and a/c martin schneider headers 3" exaust , no cat with 2 chamber dynomax. ( sounds sweet.) k&n filter. w/3" custom intake tubes, no restrictions. takes away from some of the lower end, but definitly adds to the higher end.
what kind fuel pump? from where?
i have 3" intake tubes. where did you get the fuel nosels and lines from? also how did you adjest the fuel managament for k-jetronic.? sorry trying to get everthing out of you be for you head of to Italy.
I have a freind that is a brain on tuning, he works here with me but is off today. i forget where the pump is from. we drilled out the old injector
nosel oracices to a larger diameter. The lines were bent front larger diameter brake line pipeing. tolk a hell of a long time. I was trying to find braided fuel line and flare fittings origonally.
If you are replacing your head gasket, consider one of the new all metal tri-laminated gaskets. The wide fire ring gasket is really no better than the stock gasket; the actual metal facing the compression in the piston is still only 1/32nd of an inch thick. Under high heat and pressure this burns through pretty quick.
Take a lesson from this blown gasket. You may be running too lean. The new tougher tri-lam all metal gaskets will just relocate the stress to the next weakest point... the pistons. Check with Guru or someone that can custom program a chip, or guage up with a Fuel/Air and Exhaust temp package.
03 Silver PT Turbo - Ours 86 White 951 - His 86 White 944 Manual - Hers 98 C-4 Sons 86 Gold 944 Auto - Sons 84 Maroon 944 Auto - salvaged 78 Yellow 924 - found a new home |
