Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Question on a 951 Power steering pump
Is the power sterring pump supposed to spin freely or should it make a thumping sound as it spins? I have a used pump and its not installed on the car but the wheel spins with no nooise or anything form inside the pump? Is this normal? Any input would be appreciated.
Old 02-20-2005, 07:57 PM
The pump should revolve smoothly, usually no noise as there is always oil inside, even when new from factory or ZF rebuilt unit.
What was wrong with the old one? There is a re-seal kit available.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-20-2005, 08:06 PM
i didnt realize there was a reseal kit avaiable , the orignal is only leaking. Man I need to learn more about this car. Im having the t belt watermpump and fornt engine reseal done tomorow and I am goignt o have them install this powersteering pump while there in there. I was just thinking there might be somehting wrong with it.
THanks
Old 02-20-2005, 08:11 PM
I hope your shop is also going to do the balance shaft belt because if that lets loose it will probably take out the timing belt. Then say hello to bent valves. And the belt rollers if those are original.
Strange as it may seem, I had a dealer in Chicago do my waterpump and timing belt 6 years ago before I knew much about these cars and the morons didn't replace the balance shaft belt. So last week reviewing records I discover I have a 17 year old balance shaft belt!
Old 02-23-2005, 04:13 AM
