Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Porsche Crest porsche 944 turbo 86
Greetings, I have a Porsche 944 Turbo. my problem with the car is that it is too rich and black smoking, and are at 2000-3000 rpm to regulate the treatment with low idle but does not work very little and turns off and not on again. according to the service manual already did the testing. already change the inision cap, coil, rotor, flow meter, gas regulator, computer DME and KLR, DME relay. take measurements of the resistance of the injectors and this bien.test IDLE stabilizer and according tests okay. Someone could help me????
thanks
Angel
Old 09-25-2012, 08:31 AM
Hi Angel, What is your location? You might try out Clark's Garage.com for maintenance help at the link below. I hope this will help you. The TPS Throttle Position Switch might not be working correctly.
http://www.clarks-garage.com/shop-manual/repair-procedure-index4.htm
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 09-25-2012, 08:28 PM
hi , i am of puerto rico.. today check the tps.. thanks
Old 09-26-2012, 03:59 AM
