Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
exhaust manifold
86 44 turbo.
recently purchased car. Believe i have an exhaust leak somewhere on the manifold.
can one repair these or do they have to be replaced.
Believe the leak is near the point where the tubes mate with the portion that mounts to the head.
also if they can't be fixed any suggestions.
thanks
Old 07-03-2006, 06:20 PM
winter-hater club member
nynor's Avatar
IIR, they have a tendency to crack, due to heat. i wouldn't repair it, as it will crack again. replace it with a good one from a later year turbo.
"COOL PRIUS!" - Nobody Ever
Old 07-05-2006, 06:13 PM
i believe the one on the car is from and 87 or above. not orginal equipement.
any suggestions for a reasonable priced header.
Old 07-05-2006, 07:31 PM
Try Partsheaven for a used one. Last time I checked, they cost about 300 bucks for a used one.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-06-2006, 05:53 AM
Ebay may be quite a bit cheaper, but its harder to guarantee that the manifold you're buying doesn't already have cracks. Then again, unless someone's actually pressure tested it, you're never going to have a full guarantee.
Stock 1988 951, TT aero wipers
Old 07-06-2006, 09:14 AM
Partsheaven has a 30 day return policy for defective parts. I have bought several used parts from them over the years.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-06-2006, 02:53 PM
nynor's Avatar
if you know which part is cracked (the headers are two pieces), dC Automotive sells them seperately. or, buy a performance header.
Old 07-06-2006, 05:11 PM
Thanks for the assistance. I have been to DC Auto and am confident I can get one from them. Pretty interesting place.
Any recommendations to a performance header. I do not need chromed etc and so forth. The "apparent" issue is I believe on the #1. I am seeing blow/soot on the bolts. It is not bad "yet" but I can see it coming.
thanks
Old 07-06-2006, 06:04 PM
nynor's Avatar
can you give us a picture?
Old 07-07-2006, 06:44 PM
working on a pic. can't get the light to show the area in which i think there is a leak.
Old 07-09-2006, 05:28 PM
