Engine starts with 3 wire jumper but not with good relay
Hi, as the title states, my car won't stay running for more than 3 seconds at a time. With the 3-wire jumper trick, it runs fine. I have 3 relays, the original, one from a wrecker, and a brand new one from Pelican, I took the first 2 apart to resolder them. From what I've read here and at Clark's is that the relay should be the problem if the 3 wire works. Any Ideas?
Porsche 944 1985.5 Non-tubro |
winter-hater club member
sometimes, the connections in the relay block get spread too far apart, due to using the jumpers. then, when the relay is plugged in, the contacts are not touching the terminals of the relay.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
