-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Boost Enhancer and Boost Controller (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/306429-boost-enhancer-boost-controller.html)
CJFusco 09-26-2006 06:45 AM
Can one run both at the same time, or is the boost enhancer a version of a manual boost controller? Just curious
ronin 09-26-2006 09:31 AM
if you're speaking of the Lindsey Boost Enhancer, it is not a boost controller in the conventional sense. it simply helps keep the wastegate closed longer. you can still run an actual boost controller with the LBE. having said that, it is fine to run either one without the other or both together. they perform different functions
JustinL 09-27-2006 03:20 PM
If you want some mild mods, go for some chips and a manual boost controller. Bypass the cycling valve completely, that's what the KLR uses to roll the boost on and off. You must be careful not to overboost your stock chips or you'll know about it in a real hurry.
