Porsche Gonzo
instrument cluster layout
does anyone know the layout of the instrument cluster in regards to wiring. my speedo works, all the other guages work, yet my odometer and trip meter quit.... they cluster was out of the car a few weeks ago, and wonder if the wiring harness came loose. i know there were two of them connected and like i mentioned everything else works. saying the car only went 2 miles since it stopped im not to worried, but does anyone know which harness controls the odometer
Thank you Jeff
1986 928S (we need an excorsism done here) 1988 944 Turbo (2-14-2000 - 6-6-2008) Last Video Made in the 944 turbo (5-28-08) http://www.youtube.com/watch?v=UmjhT7AndEQ |
Even though the speedo on your car is electronic the odometer is mechanical. It is driven by a gear which engages a worm gear to drive the odometer. This gear can slid along it's shaft and disengage from the worm gear, or is worn/ broken. You will have to pull the speedo out and have a look.
luck Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Porsche Gonzo
saying ive never had a problem with it, and to think about it for a sec it has 18 years on it, but it only has 93,000 miles of actual spinning if its mechanical. it has to be from when it came out of the car the last time
you made me think, thanks for your response
200k plus on mine the speedo/odometer work fine..
Iirc some times the reset button gets hung half way. Push it a couple of times (with car stopped) see if it works. Porsche does not recommend doing that with the car moving, but I have had mine stick once 10 years ago I think and I taped it while moving (The reset button) It started working again. Sox
