-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   i dodged another bullet (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/333663-i-dodged-another-bullet.html)
nize 03-04-2007 12:06 PM
so i noticed an unusual amount of belt dust, rough idling/running, and a whining noise from the belt area;
http://gallery.silentmedia.com/d/58606-2/IMG_1998-2.jpg
diagram of belts;
http://www.clarks-garage.com/graphics/time4.gif
open up the belt cover and both the timing and balance belts are worn in an unusual manner;
http://gallery.silentmedia.com/d/58610-1/IMG_1997-3.jpg
apparantly, one of the inside cover screws had gotten loose and after travelling around the belt system, ended up lodged by the upper balance shaft sprocket. also note that all of the teeth on the backside of the belt have been shaved smooth!
http://gallery.silentmedia.com/d/58613-1/IMG_1995-3.jpg
so now i have a custom one-of-a-kind screw-slot;
http://gallery.silentmedia.com/d/58616-1/IMG_1996-3.jpg
ae1969 03-04-2007 02:42 PM
Holy ****.
Another plus for not having my front covers on.
soxnail 03-04-2007 03:02 PM
I have a question. I have been told by Porsche mechanics that the 944 na is an interference engine due to its higher compression, but the 951 has lower compression and the piston tops are concave so a belt failure would not damage valves/rods etc. In other words a belt failure in a 951 is not catastrophic. True / false
Sox
ae1969 03-04-2007 08:26 PM
Sox
False. It would be if you could notch some relief into the piston tops. Not enough material unfortunately.
soxnail 03-04-2007 08:30 PM
thanks...not that I was going to test this theory.
Sox
Jeff Alton 03-04-2007 09:30 PM
The 944 motor, for arguments sake, is basically half of a 928 motor. (in general terms).....
I am the only person I can find that broke a timing belt in a 928s4 (32v) motor and did not have the pistons hit the valves. 190 compression on all cylinders after it broke. It might have beed because it let go when I turned the motor off, but I would like to know if anyone else has survived the incedent?
So, you *might* survive a broken timing belt, but the odds are you will be openning your wallet and seeing your banker!
Cheers
nynor 03-05-2007 07:20 AM
sheesh... that was a close call.
