Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Super Moderator
nize's Avatar
hp calculation ?
i've found a lot of hp calculators based on quarter mile times, trap speeds, and even a very good one based on known torque values;
http://vlsicad.ucsd.edu/~sharma/Potpourri/perf_est_intro.html
i'm wondering if there's a way to calculate hp and/or torque based on the following info;
time from 2krpm to 6krpm in fourth gear
anybody know?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 03-20-2007, 01:12 PM
You can determine the average horsepower over the range of speed change (linear movement of vehicle) relatively easily. However, you lose all the power that went into making all the rotating parts go faster as well as windage losses.
For a quick calculation you can compute the change in kinetic energy between the two speeds. That change divided by the time that was taken to do it represents the power that reached the pavement minus the energy losses due to air resistance. For the latter you'd have to know the drag coefficient of the vehicle and the frontal area of the vehicle plusthe density of the air. For the rotating parts, you'd have to know moments of inertia of every rotating part in addition to the rotational velocity
changes. There is kinetic energy associated with rotation as well as with linear motion. The inertia stuff is too complicated to do here. Moments of inertia are highly geometry dependent.
But neglecting the air-rotation business you can say (in US units).
Change in kinetic energy = 0.5*m*(vf**2-vi**2) where m is the mass of the car which is the total weight of the vehicle divided by 32.2. Vf and vi are the final and initial velocities of the car in feet/second, respectively. The **2 means squared.
The units of the above are foot pounds. Dividing by seconds gives you ft-lbs/sec, the unit of power. One hp is 550 ft-lbs/sec. Here's a sample calculation.
Car accelerates from 70 to 100 mph in 4 seconds. It weighs 3100 pounds with you in it.
DKE = 0.5 * 3100/32.2 * (146.7**2 - 102.7**2) = 5.281d+05 ft-lbs.
Power = DKE/time = 5.281D+05/(4.0 * 550) = 240 hp
Thus you put an average of 240 hp into the change of speed if you did it in 4 seconds.
There probably is a correction factor that can be applied to account for the losses of spin up rotating parts and power lost to drag of the vehicle. But this is a start.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-21-2007, 07:04 AM
Nize -- Do this after the dyno day -- Then tweak a final coeffecient to multiply your answer to, in order to get your times to match your dyno times.
Lawrence's example used 70-100.
On the dyno do that -- Plus one more (60-90?)
Then when you try to do your street dyno, you can do the same thing, with the dyno calibration number, and see how close you get.
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 03-21-2007, 08:49 AM
Super Moderator
nize's Avatar
lawrence, that is excellent. thank you.
i am going to try to make an excel spreadsheet to plot the various sections (20-40, 40-60, 60-80, 80-100, 100-120) and then use that info to make a 'street hp' graph. once i have that, i can also make a matching tq graph.
then i can get some more use out of this standalone system;
Old 03-21-2007, 09:15 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Great info lawrence!
You were paying attention in physics. hehehehe
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-21-2007, 11:30 AM
meister member
speedracing944's Avatar
Man, my spring break just started. I don't want to look at that stuff during my time off
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-31-2007, 05:41 PM
