Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Lindsey Boost Enhancer - Adjustment
I came to find that the lock nut that is loosened in order to adjust the Lindsey Boost Enhancer on my car was a little loose, and as a consequence the adjustment screw might have moved, altering my car's boost pressure.
Can anyone tell me how many threads are visible on the adjustment screw in stock LBE form? I want to tighten it down, but I don't want to run any higher than stock LBE boost - I am waiting for a 3.0 FPR to come in the mail and don't want to blow a head gasket before then.
Thanks.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 03-27-2007, 08:40 AM
Porsche Gonzo
onehot951's Avatar
Send a message via AIM to onehot951 Send a message via Yahoo to onehot951
This is what mine looks like and its never been adjusted. I threw in 2 pics to give you a different view on the threads
Good luck
1986 928S (we need an excorsism done here)
1988 944 Turbo (2-14-2000 - 6-6-2008)
Last Video Made in the 944 turbo (5-28-08)
http://www.youtube.com/watch?v=UmjhT7AndEQ
Old 03-27-2007, 03:35 PM
from what Dave at Lindsey said its excatly 4 pennies that fit inside to make it stock...man that things is insane. It makes the car pull harder and boost faster shoulda done this moon ago.
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 03-27-2007, 06:44 PM
Writer/Teacher
CJFusco's Avatar
What I want to know is, does it REALLY function as a boost controller? I understand how it closes the wastegate and thusly makes the turbo spool at a lower RPM, but if you adjust it for higher boost, won't it delay the turbo spooling a bit?
Old 03-27-2007, 08:31 PM
Writer/Teacher
CJFusco's Avatar
BTW, thanks for the pics.
Old 03-27-2007, 08:57 PM
Super Moderator
nize's Avatar
the LBE not only increases boost (and acts as a boost controller), it also bypasses the cycle valve 'cripple mode' failsafe.
user beware.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 03-28-2007, 01:08 PM
nize,
explain your concerns
Old 03-28-2007, 01:15 PM
Super Moderator
nize's Avatar
simple, you can even test it yourself on a stock car that has a known working cycle valve (they seem to be getting more and more rare);
1) without LBE, test WOT boost under normal conditions, note the amount of boost (it should be higher than 1.5bar)
2) without LBE, disconnect the wire leads on the cycle valve. this will simulate a 'failed cycle valve/knock detected/cripple mode scenario. test WOT boost. (it should boost only to 1.2bar cripple mode)
3) with LBE, test WOT boost under normal conditions, note the amount of boost (it should appear to be the same 1.5bar).
4) with LBE, disconnect the wire leads to the cycle valve. test WOT boost (it will boost past 1.2bar).
this proves that the LBE bypasses the cycle valve stage two knock protection/cripple mode failsafe, which is exactly what a boost controller does.
Old 03-28-2007, 01:28 PM
74goldtarga's Avatar
So, what is just as effective but safer?
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 03-28-2007, 06:50 PM
Super Moderator
nize's Avatar
wolf3d ems with j&s safeguard;
wolf3d -v400 review
Old 03-29-2007, 09:00 AM
That makes sense but I am guessing the system costs more than the replacement cost of a blown head gasket .
I like looking at data, and I like the idea of being able to ratchet up the boost/hp safely with feedback. How long does it take to install/set-up?
Old 03-29-2007, 05:42 PM
Super Moderator
nize's Avatar
it's plug-and-play, takes less than an hour to install.
it comes with a generic (ie; factory) tune, and/or a 'modded' tune. the fine-tuning is what takes time.
Old 03-29-2007, 08:43 PM
