Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 944 Turbo and Turbo S
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Slight backfires (?)
A few days ago, I did a tune up on my car, replacing spark plugs, the wires, air filter, oil change... at (roughly) the same time I replaced the stock FPR with a 3.0 unit so I can safely run the LBE (=slightly more boost).
Since then, I've noticed that if I let off the gas abruptly in 1st or 2nd, I'll get a little bit of a backfire. In 2nd it's more of a muffled "burble", but in 1st its more of a "pop".
I know that high-performance cars sometimes have "burbling" from exhaust off-throttle. Is this what I am experiencing? Or is it something I need to address (such as running lean)?
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 04-03-2007, 03:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Ornery Bastard
I've noticed that in a few chipped 951's. Seems pretty normal, but I'd do a Dyno run with a wideband O2 sensor and see how the mixture's doing. Be sure to measure at the test port and not the tailpipe because the cat will change the readings if you measure at the tailpipe.
Shifting is an art. Learn it, love it, live it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 04-03-2007, 05:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Writer/Teacher
CJFusco's Avatar
If I am getting combusting exhaust gasses in the exhaust, I am guessing that would be closer to running RICH than running LEAN, right? I am most worried about running lean and blowing the head gasket.
Old 04-03-2007, 06:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Junior Member
yahoo's Avatar
backfire or postfire??? Isn't a postfire when the unburnt fuel ignites after the exhuast valve is closed? and a backfire when it ignites in the intake manifold? Correct me if I'm wrong.
And with a backfire/ postfire you are running lean. Thats according to Wikipedia
Old 04-03-2007, 08:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
cold starter
JustinL's Avatar
You'll get a burbling popping exhaust if the mixture is too lean. You can get really loud bangs if the exhaust is hot and you're running it rich. Because it's off throttle, the cylinder pressures won't be terribly high like under boost, so I wouldn't worry about it too much.
When you upped the fuel pressure did you change your chip to compensate for the added fuel, or was your chip supposed to be used with 3bar fuel pressure?
EDIT-- In case that was confusing... you are supposed to be under a fuel cut with the throttle closed at RPM above 1600. You are probably getting popping because instead of having no combustion, you are getting a bit of fuel during overrun.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 04-04-2007, 06:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Writer/Teacher
CJFusco's Avatar
I got the 951Max chip BEFORE getting the 3.0 FPR, and IIRC, the chip was configured for the stock FPR. This makes me think that the car is running a little RICH at low RPM/low gear off boost, because more fuel is being piped through.
I have noticed that I only get the pops when the car is warmed up, so that kind of goes along with the running rich theory...
Old 04-04-2007, 07:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
cold starter
JustinL's Avatar
Yes that's right it's running rich compared to what it's supposed to (fuel cut) off throttle, but your AFRs are likely leaner than stoich. On throttle, you are also right, it's probably rich throughout the rev range.
Old 04-04-2007, 08:11 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
cold starter
JustinL's Avatar
Old 04-04-2007, 08:23 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
