weird problem!951
Guys I need some help !!!
I have 951 1986 I test drove car yesterday in 100mile trip, car has a problem, always show when car is warn up, for example in 4 gear at 4000rps just crussing speed 75 and you kind feels car is not keeping power then you put gas and car dosn't react !pump gas pedal couple times and then it acts weird and the goes fine again! when this happen you push gas pedal and engine feels like if not getting fuel in to, even the boost gauge dosen't show rise in boost for 1 or 2 seconds and then it rise boost and seems to operate fine I check engine and it looks like the TPS sensor has the tap missing you can see the little wires and things inside !also my air filter housing is most taps broken and air filter is not 100% secure !main question should this tps be problem !or look something elsehttp://forums.pelicanparts.com/uploa...1177716279.jpg |
1) replace tps with a known good one.
if this doesn't work; 2) remove injectors and have them professionally cleaned and flow-matched. www.witchhunter.com |
my car started doing this then got worse now i'm standed; did you figure out what was wrong?
Re: weird problem!951
| All times are GMT -8. The time now is 10:27 PM. |
