Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Porsche Gonzo
onehot951's Avatar
Send a message via AIM to onehot951 Send a message via Yahoo to onehot951
leakdown test results
leakdown test mid 2002
10
9
4
8
does that mean its leaking 10% on one of the cylinders?
are these normal numbers
Thanks guys
1986 928S (we need an excorsism done here)
1988 944 Turbo (2-14-2000 - 6-6-2008)
Last Video Made in the 944 turbo (5-28-08)
http://www.youtube.com/watch?v=UmjhT7AndEQ
Old 05-11-2007, 11:03 AM
soxnail's Avatar
I would venture a guess but I need to know how the test was done.
Normally the main pressure gauge upstream to the restriction should be 100 psi. Then the second gauge shows how much leakage there is.
So if the test shows 90 psi on the second gauge then there is a 10% leak. If the numbers you have posted are the drop from 100 in each cylinder then yes it would be 10% 9% 4% 8%. These would be very good numbers as new engines get 5% and anything under 15% for a 80's car is very good. 20% would be the upper limit, as the percentage shows the engines conversion efficiency and a 20% loss is pretty drastic.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 05-11-2007, 02:39 PM
Porsche Gonzo
onehot951's Avatar
interesting, he said they were really good i just didnt understand what it actually meant. i had a compression check done and cant remember the results and he couldnt find them in his computer. on a different note. i ran some bars engine oil leak stop through the porsche and noticed a very nice difference . as of right now. there is NO oil on the exhaust system even after sitting for 45 mins. there are a few drops under the car but they seem to be conveniently located under the oil drain bolt.... i need to replace the copper washer on the drain plug apparently. ive used bars radiator products before and they seemed to work very well. any thoughts sox?
Old 05-11-2007, 03:00 PM
soxnail's Avatar
Sorry amigo don't know that product..
Sox
Old 05-11-2007, 03:28 PM
