-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Before i break out a voltmeter (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/348722-before-i-break-out-voltmeter.html)
onehot951 05-26-2007 05:12 PM
Curious what everyone else is getting on the dash volt meter guage. im getting EXACTLY 12 volts... with the headlights and foglights running. if i turn on the fans inside the car and turn on the rear window defogger, it drops below 12 volts, not by much though . it does seem to rise a little as the tach rises but not much over the 12. Are these pretty accurate?
Im going to hook up a volt meter at the battery and see what its getting at idle and then what it gets as it rises off idle
nynor 05-26-2007 06:09 PM
mine is totally whacky. it jumps all over the place and gets stuck pegged at the top. i used my voltmeter to verify the alternator and it was fine. i don't have problems with other gauges in the car, just that one.
soxnail 05-26-2007 10:21 PM
I get 13 to 14 V on it if the car has been sitting. It drops to 12 plus after a while. If I turn on the AC, lights, and rear defog then it drops to about 12 V but never below.
Sox
Lawrence Coppari 05-27-2007 03:07 AM
Mine sits at about 13.5 with no accessories on but gets close to 14 when the car is first started. With AC (blower) and headlights on, it reads about 12.5V.
