Tach,and boost guage problem
I just replaced my engine in my 86 turbo and my tach, and boost gauge no longer work.Icant find whare to plug in the connection end for the Timing Mark Senser/sender for T.D.C. This senser/sender is located just below the referense sensers ,and it looks like a mini referense senser and it has a round plug end . I would highly appreciate any information on the location of the other end to plug this into. Thanks.
Super Moderator
have you checked this?
http://clarks-garage.com/shop-manual/ign-02.htm
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Thanks, Im still puzzuled as to whare the plug end plugs into,but my tach and boost gauge problem are related to the site you provided.Thanks again.
Super Moderator
the plug end plugs into the wiring that's located at the firewall, right next to where the other plug goes.
Could you be more specific as to the location. I have looked for hours and I can`t find it. I couldn`t even find the plug end on a spare wiring harness.Thanks for your responses.
Super Moderator
have you checked the porsche PET catalog? the link is in the first thread in this forum. this page might help you;
If you are referring to part #24 (Timing Mark Sensor for TDC) in the diagram that Nize provided, it does not plug into anything during normal operation. That sensor is only used by the service technician to find TDC.
A.J.
89 944 Turbo Guru Chip Lindsey Boost Enhancer 3bar Reg. |
Thank very much. You both were very helpful. Thanks again. It was #24 I was referring to.
