-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   951 standalone timing maps (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/349033-951-standalone-timing-maps.html)
sickwidit951 05-28-2007 06:06 PM
Hello everyone, it's been a while since I posted here. I finally found the time to finish off my megasquirt conversion on my 944 turbo. I just took it for the first drive today and everything is working really well. I could use some input on how to setup my ignition timing table. Mine is working great for cruising around but I'm not sure how to tune it under boost and higher rpms. I plan to tune it on a dyno very soon but it would help a lot if I had a reasonable map to start with. My car is pretty much stock except for the MS, and I plan to run about 15psi until I get a new turbo (I'm running the k-26 #6 right now). Any input, especially full tables, would be greatly appreciated!
Best,
Bob
nynor 05-28-2007 07:50 PM
wow, strong work! pictures?
sickwidit951 05-28-2007 08:07 PM
http://forums.pelicanparts.com/uploa...1180407425.jpg
Thats what it looked like a few days ago. Since then I have finished the EDIS wiring, cleaned things up A LOT, and installed flex-braid over most of the exposed wiring. The piece of aluminum next to the cruise control is a ground plate. It's grounded to the engine and chassis and serves as a temporary common ground for all of the critical sensors and other components. Please no flames about the mess under the hood, it's still a work in progress. That pipe / filter setup is just a temporary replacement for the factory AFM / Airbox. I plan to come up with something better in the near future.
http://forums.pelicanparts.com/uploa...1180407738.jpg
http://forums.pelicanparts.com/uploa...1180407885.jpg
http://forums.pelicanparts.com/uploa...1180407980.jpg
http://forums.pelicanparts.com/uploa...1180408017.jpg
ae1969 05-29-2007 11:52 AM
HOOOOORAY!!!
COngratulations on joining the club
I run MSII with EDIS.
I run a larger turbo but I have a stock ignition map as well on my other computer.
I will dig some up for you.
COngrats!!!
speedracing944 05-29-2007 09:16 PM
Congrats on the MS.
ae1969 has some great cold start enrichment maps.
You should post this on the 944 forum as well. Hopefully more people turn to MS for the 951s.
I built (soldered and everything) a MS II system for my Vette LT1 swap in the 944. I can't wait the swap to be done so I can play with the MS.
Congrats once again.
Speedy:)
sickwidit951 05-30-2007 12:57 PM
Thanks! and I too have been considering a v8 swap if I blow this thing up.
AE1969, that would be great! As soon as you can because I can't wait to let this thing loose!
I remember reading about MS-II in a Subaru magazine around this time last year and thinking "damn I need that." When I saw the price, I was sold. I bought the unassembled kit and soldered the whole thing.
It took a while to sort out the triggering but eventually I splurged on the Clewett Engineering kit and had a 36-1 wheel machined in place of the 60-2. Very pricey but good for peace of mind.
I'm hoping to get the ignition timing reasonable dialed in by this weekend because I can't wait to try this thing out on the autocross course. Heck, it's Wednesday so I might even go to the dragstrip later to do some tuning.
Best,
Bob
ae1969 05-30-2007 07:50 PM
http://forums.pelicanparts.com/uploa...1180579178.jpg
Russell had this on one of his maxtune demos.
Things that worked for me......
~10 degrees at idle and the surrounding cells
At cruising you can easily get away with 25-30 degrees.....
IF you were to do a dyno run......... lets say from 1500 rpm up... you would see a curve.
It would move from the 10 degree cells at 30-40kpa upto 20 degrees around 100kpa.... and quickly creep up as you develop full boost around 27-2900 rpm. At that point you want a bit of a dip in timing (~15 degrees) as you can see in the stock map....... once on full boost .......past 3500 rpm it goes up slightly......... 17,18,19 etc....... Now you can play with this to get faster spool and stronger pulls but I would play it safe for now.
Those are your critical values.
If you have a screen shot of your map I can point out what cells to watch out for..........
P.S I found megatune incredibly helpful in setting AFRs..........
P.S.S. In case you were wondering I am the president of the Megasquirt 951 club. JustinL is vice president ........and since you are third in line you are secretary/treasurer. Glad to see the organization is growing!
SmileWavy
sickwidit951 05-31-2007 08:03 PM
http://forums.pelicanparts.com/uploa...1180665014.jpg
Thats what I have right now. I tried my best to translate the 951max table into megasquirt form. It turns out that I had forgotten to jumper the js10 to ign on the board so no SAW was getting to the EDIS module. The problem was pretty obvious when I hooked up my timing light to set the trigger offset.
I realized that even though we have different turbos, I can probably use the same settings as you off boost, which is what seems to need the most attention right now. Do you think you could post a screen shot of your ignition table?
I didn't set up any IAT retard ...I think that would be too may variables at the moment.
I ran a couple cycles of VE analyzer on my VE table. It's frustrating though because megatune likes to freeze my computer when the megasquirt is hooked up. Now I have AMC setup with mild EGO control so my fueling is pretty well refined albeit on the rich side under boost.
The next step is to strap this thing on a dyno and see what really needs to be done.
Thanks for everything!
Bob
JustinL 06-01-2007 08:48 AM
I've found that 4% ego works about right for me. Any more than that and the oscillations get a bit too high for my liking.
speedracing944 06-01-2007 09:01 AM
So once I get mine up and running can I be appointed the Court Jester?
Speedy:)
JustinL 06-01-2007 09:13 AM
I'm staging a coup d'etat when I get my 944 n/a squirted...
But I'll need Alex's help so there may be a conflict of interest. Maybe he'll stay president after all.
sickwidit951 06-02-2007 12:34 AM
http://forums.pelicanparts.com/uploa...1180769011.jpg
I spent some more time on it and made some little changes. I'm only running 10psi right now so that top row isn't really coming into play. It actually felt stronger with about 5 degrees more advance across the board but I think thats just because my mixture is pretty rich. Under boost I was seeing low 10s under boost between 4k and 5k rpm. I'm trying to lean it out to a nice, conservative 11.5 or so before I spend some time on the dyno. It's really fun finding an open road and doing 3rd gear runs and making tweaks.a Very satisfying watching it come alive. I can only imagine how this thing is going to pull with a couple more psi, a 50 trim, and a 4" exhaust.
ae1969 06-02-2007 07:37 AM
Nice job....... you are pretty much there. With an EGT and wideband you would be able to nail those WOT values and optimize your cruising cells....but overall the car should drive well.
Carefull on how much timing you feed it up top........ I run a similar timing curve with a bigger turbo so this curve should work fine. Some may find it slightly aggresive but it will be fine. What are you running for gas?
What are you idleing at? I am around 35-38 kpa at 950 rpm...
That 1300 rpm , 40 kpa cell at 11 degrees may cause minor oscillation.... You probably wont even feel it.........but a few months from now. Every little hiccup will be magnified. You will 'FEEL' every little change.
WHen you decide to shoot the boost up. You should set the upper rows as follows.
Lets say you want 200 kpa to be your max. I would set the second top row to 200 kpa and the upper to lets say 225kpa. With tapering timing values.... just as a little safety net in case you over shoot. I have overshot too many times setting my boost controllers.
Great job. I would drive with my laptop to work daily. Now I just drive. I miss tuning :( I think I will go and change something on the car just so I can play again.
Congrats again.
Yours truly.
El Presidente
sickwidit951 06-05-2007 02:01 PM
Thanks for the advice! I did notice the hiccup that you were talking about and set all the surrounding cells to 11 degrees, thats where it seems to feel the best.
I pulled some timing up top which allowed me to lean out the mixture into the mid 11s. It's funny how it seems to run fine with a lot more timing up top but it just loses some power; I have yet to hear any pinging under boost but it just feels sluggish with too much advance. I'm running 91 octane California gas. When I run it at the strip tomorrow I plan to mix in some 100.
I finally got my computer to stop freezing when megatune is open so I've been doing a lot more datalogging which has helped a lot with fine tuning the fueling.
The car now feels much stronger off boost! It actually pulls pretty well from 3000rpm up without any boost.
So here's what the new table looks like:
http://forums.pelicanparts.com/uploa...1181077040.jpg
I studied some other maps to get a better understanding for how much to retard the timing as the boost increases.
ae1969 06-05-2007 02:46 PM
I agree with your timing comments.
It is a fine line....... you will find that increasing timing you will improve response off boost more so than you would on boost.
On boost if power is what you are after then you are better off pulling timing back a couple of degrees and cranking up the boost..... but that little turbo is starting to get out of its range. EGTs become a problem when you pull back too much.......hence the tricky balance.
I like your timing curve. I see that you are finding a way to increase your spooling time. Pulling the timing right as its spooling up at 2300 rpm is a nice trick....(12.3) value. It is a nice way to get the heat up and spool up quicker.......
Have you done this before?
sickwidit951 06-14-2007 12:22 PM
Update: Last night I took it to the dragstrip to datalog some runs and see how things are doing. I was hoping for a mid 15 running my 10psi setting (timeslip says it was 99 degrees). Very first run I pulled a 14.9 at 97 mph. Thats very close to my best ever trap-speed running 15psi with Autothority chips. AFR's were SOLID at almost exactly 11.5 the whole way ...the datalog is a work of art. So I decided to turn up the boost a tiny bit.
On my second run I decided to do a more agressive start and ended up pedaling the tires like a maniac and almost missing the shift into second. I was amazed when I got my timeslip and it said 14.1 at 101mph! My best ever with the Autothority chips was 14.5 at 97 and this was only my second ever run on the megasquirt. My 60 foot was a 2.4 but I've managed a 2.2 before so I know this thing can do 13s. This is a 100% stock car except for megasquirt, suspension, and a cone filter.
I didn't do any more runs because the oil pressure started doing really funny things in the staging lane. Everyone says its the gauge but better safe than sorry.
I'll try to pull up a screen shot of the datalog from my first run, it's pretty fun to see. I didn't log my second run because I didn't have a whole lot of time after my first and I wanted to focus on my driving.
Bes,
Bob
nize 06-14-2007 12:30 PM
nice! videos?
sickwidit951 06-14-2007 04:59 PM
Here's the datalog. I don't have a video but if I go next week I will try to get one. I might even have my 4inch exhaust by then ...it will be hard not to run 13s with that thing!http://forums.pelicanparts.com/uploa...1181865565.jpg
ae1969 06-14-2007 05:16 PM
Nice job! Strong trap speed.
Are you noticing any odd things in the ignition side.
I see a few subtle bumps on the rpm log.
I had ignition noice that became evident as I pushed the boost up. It was not apparent at 11-13 psi..... but as I pushed passed 15 psi........ I began snuffing out the spark...........
I switched to resistored plugs now and running a gap of 26-28 thou.
sickwidit951 06-15-2007 01:45 PM
I'm running resistor plugs right now. I zoomed in on the log and I see what you mean. There are no peaks or dips in the rpm log but there are spots where the slope decreases or increases a little. I might try to raise to the lag factor to see if I can catch something. One thing the log tells me is that my tach is reading a little bit low. I was letting off the gas to shift right before the orange section of the tach, and you can see that in the datalog the TP stays 100% all the way to 6700rpms (yikes, I definitely didn't mean to spin this thing that high, especially not in a drag race). The tach is still driven by the DME so I may try switching it over to the EDIS tach output.
My new exhaust is on back order and I'm impatient so I might order a new turbo to keep me entertained in the meantime.
sickwidit951 06-15-2007 01:49 PM
http://forums.pelicanparts.com/uploa...1181940529.jpg
sickwidit951 09-08-2008 11:35 PM
I'M BACK!
Long story short I'm going back to the strip this Wednesday looking for some better numbers.
It's been a slow year with regard to my car, but I just got it up and running again this week. Let's start off with the new specs:
T04E 60-1 HiFi w/ #8 exhaust housing & Turbonetics Stage V turbine (AKA LR Super 61)
Lindsey Racing 4" Exhaust (Magnaflow)
Siemens 55lb (570cc) Low Impedence Injectors
Megsquirt-II SMD-3.57
(One might say it's the poor man's version of a Vitesse Stage 3 Kit haha. Total Cost was around $1800)
I spent a lot of time chasing my tail after an electrical snafu last summer, but it looks like my car is back and ready to brawl with the new SMD megasquirt. I never trusted my soldering on the old board. I have the fine motor skills of a young elephant cub ...and the patience of one!
I also installed an Autometer Z-series Boost Gauge and Innovate Motorsports AFR Gauge on the A-pillar ...yea I admit its looks kinda goofy but it's a convenient spot and I'm young enough that it looks alright to me.
At first I had a bunch of trouble trying to get the car to run right with the 55lb injectors. It would go lean and bog all over the place for no apparent reason. Bumping up the injector opening time from 1.0 to 1.3 ms completely fixed this! Now it idles wonderfully at 1000rpm and cruises around just fine. The few times I've been on boost have been awe inspiring! The 60-1 HiFi doesn't seem laggy at all to me. I know it's a pretty oldschool turbo but frankly I think it's awesome.
Anyway, I look forward to posting up some pictures and results later this week. Hopefully I can get the fuel all dialed in between sailing and my dentist appointment tomorrow.
Best,
Bob
nize 09-09-2008 12:13 AM
awesome, welcome back! looking forward to your results and some dynos. :)
sickwidit951 09-09-2008 05:30 PM
I'm running into a couple more issues. It seems that even running only 13psi I'm maxing out the 55lb injectors. At 6000 rpm the duty cycle is just over 80% and the AFR is 12.1:1!
I'm thinking that these injectors should easily be able to support 13psi so perhaps the issue is one of the following:
Fuel Filter
Fuel Pump
Fuel Pressure Regulator (It's a 3 bar, almost brand new)
Fuel Damper (lol I don't see how this could be a problem but who knows)
Regardless, this thing is FAST at 13psi!! I'm running a fairly conservative ignition table but nonetheless WOW! Hopefully I can get everything sorted out before tomorrow afternoon so we can get some drag times. Even if the fuel issue doesn't sort itself out, I'll do some low boost runs.
nize 09-09-2008 05:51 PM
do you have a fuel pressure gauge? it would be handy for troubleshooting this issue.
sickwidit951 09-09-2008 10:15 PM
No, I almost bought one last week though. I'm kicking myself for not doing it now!! I'll pick up a new fuel filter tomorrow morning ...the downside is that if it does fix the issue I'm going to have to re-tune a lot of stuff :(
Shoot, I might just run at 12psi. I have a feeling that will be enough to nail down some runs in the high 13 second range. Right now it's pulling so hard in 3rd gear that I keep thinking I'm in second, only to look down and realize I'm doing 90!
17-18 degrees advance more or less across the power band at 13psi. I think the rich AFR's make this a fairly safe setting for now.
blown 944 09-10-2008 01:23 PM
do you have a good boost source going to the FPR?? If not it may not be rising correctly and you are running 13 psi at what ever static pressure is vs running at static + boost pressure.
Good luck btw I have been so PO'd at my car the last few times up that I don't even bother with ET anymore and just look at MPH.
Hopefully the new clutch will solve it and I can finally post a respectable timeslip. I have a bunch of slips with 14 second ET's and 116+mph. Even a 15 second slip at 118. Fricken car is a ***** when you cant' launch or shift hard.
Anyway GL again
sickwidit951 09-10-2008 06:51 PM
Yea I'm pretty sure I have a good boost/vacuum source going to the FPR. It comes off the intake manifold and goes to the FPR, Damper, and Bypass Valve.
But Anyway, even with my fueling issues, here was my 3rd run. I'll refrain from excuses and just say, there was A LOT left on the table!
[IMG]http:http://i76.photobucket.com/albums/j12/951racer/Porsche/IMG_1635.jpg//[/IMG]
http://i76.photobucket.com/albums/j1...e/IMG_1635.jpg
sickwidit951 09-10-2008 06:53 PM
I was in the right lane, so thats 13.574 @ 104.84 mph. The 2.288 60 foot is deceiving, I had crazy wheel-spin after the 60 foot and the mustang in the left lane actually got ahead for a second.
sickwidit951 09-11-2008 02:22 PM
Just picked up a new fuel filter. Hopefully that will fix my fuel starvation issue. Might try to get my hands on a fuel pressure gauge as well, but car is already starting to look like an airplane cockpit from the driver seat with all these gauges.
Anyway, next Wednesday I'm aiming for 12s if this fuel situation is solved.
sickwidit951 09-12-2008 01:21 AM
New fuel filter is IN! Also verified the vacuum/boost connection.
Will test tomorrow morning! Kinda have my doubts that this will actually fix the issue but who knows...
sickwidit951 09-12-2008 11:59 PM
Still going lean (maybe a marginal improvement but I'm probably just being optimistic). I'm going to order a Walbro fuel pump and adjustable FPR. The LR fuel rail kit is definitely a tempting upgrade because it would make the engine look so much nicer but it would also be sort of a waste of money and a pain in the ass when smog time comes around.
nize 09-13-2008 08:41 AM
before you blow more money on parts, i'd get a fuel pressure gauge and verify you actually need new parts. :)
sickwidit951 09-14-2008 05:15 PM
Yeah, thats probably the thing to do, I'll see what I can find at Jegs. It's time for a new fuel pump anyway so that's not a complete waste of money. The adjustable FPR would also be a nice piece to have. BAH why not get all 3?
The fuel filter may have helped some, because the car seems to be able to handle 14psi now without issue (AFR stays in the high 11s). 14psi is plenty for laying down rubber and joyriding around here :D
Bad news is, no strip this Wednesday and further progress is going to have to wait because I'm going back to LA for a couple months :(
On the bright side, maybe Santa will bring a CEP Stage III head and Cam this year?
nize 09-14-2008 06:13 PM
i got the autometer 2663, electronic and safe to mount in the cockpit. it's nice not having to pop the hood to monitor fuel pressure;
http://performanceparts.com/part.php?partID=166906
http://performanceparts.com/performa...meter_2663.jpg
