Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
gap for sparkplug
wut is the sparkplug gap on a 88' porshe 944 n/a
Old 06-23-2007, 01:23 PM
winter-hater club member
nynor's Avatar
from clarks-garage.com:
1. Check the gap on the new spark plugs. Most Bosch plugs come pre-gapped. However, they should be check anyway. The gap should be 0.7 to 0.8 mm (0.028 to 0.031").
2. Coat the threads of the new spark plugs with a light coating of engine oil.
3. Disconnect the first spark plug wire. Replace one spark plug at a time to keep from getting the plug wires in the wrong location.
4. Using the spark plug socket and ratchet, remove the first spark plug.
5. Install the new spark plug and torque to 18 to 22 ft-lbs (25 to 30 Nm).
6. Reconnect spark plug wire making sure the connector is fully seated on the spark plug.
7. Repeat Steps 2 thru 5 for the remaining spark plugs.
you should be posting in the 924/944/968 forum if you have a NA.
welcome to the forum!
"COOL PRIUS!" - Nobody Ever
Old 06-23-2007, 02:21 PM
