951 Blend door motor??
Does the 951 have a blend door? I am having AC trouble. Mechanic says it seems to be expansion valve which is no big deal, but when I called after hours to get a status report the service advisor said something about a blend door motor...and I have not been able to find one anywhere?
Dick 87 951 |
It has a mixing chamber with a gate (motor controlled) that mixes cold and hot air...
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Do you have a correct phrase for what it's called or a part number or a seller for the motor?
I don't have the part number in front of me but could probably chase it down, but here is a picture of the schematic.
Sox ![]()
I have been to several websites typing in Blend Door Motor and NOTHING comes up....a part number would be greatly appreciated if possible....thanks for your info.....
964.624.324.00 MOTOR CENT TEMP MIX FLAP try this no guaranties.
Sox
Thanks Much
We have those motors in stock.
Good luck, George Beuselinck |
