Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
adrian1's Avatar
Porsche Crest gauges stopped working???
I bought my 1986 951 and 2 days later all the gauges stopped working including the sunroof motor. When i checked the fuses they were fine but had no power. However when i add power to that fuse everything works. Where should i start, any suggestions???
1986 PORSCHE 951 3.0 project has begun!
1989 IROC-Z(Show Car)
1961 Willys Jeep w/ 283 chevy(straight open headers)
1995 Dodge Ram 2500 HD
1981 Corvette 4spd
Old 07-31-2007, 06:44 PM
soxnail's Avatar
As far as a quick glance tells me the fuses for the instrument and the roof lifting motor are separate..So when you say the gauges stopped working you mean the all the gauges like fuel and coolant temp etc. or the lights in the instruments? Also if you apply power to which fuse and which side of the fuse?
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 07-31-2007, 08:08 PM
adrian1's Avatar
I think its fuse 36 its the one for the intruments not the lights. When i add power to the top of any side i get all of the gauges to work and the sunroof starts working also. Its the same fuse that gives power to both so somewhere the that section of the fuse box isn't geting power. Yes all the guages show nothing at all fuel,water temp,rpm,mph,oil press, etc....
Adrian
1981 Corvette 4spd
Old 08-01-2007, 08:49 PM
Super Moderator
nize's Avatar
oh boy, electrical gremlins!
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 08-01-2007, 11:20 PM
soxnail's Avatar
Under the fuse box is a jigsaw puzzle of copper pieces. You may have to take the fusses out and take the plate off and see if the copper underneath is intact.
Sox
Old 08-02-2007, 08:17 PM
