-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Another modded 951 not starting (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/360869-another-modded-951-not-starting.html)
Flitzr951 08-15-2007 10:55 AM
My issue was just a lack of understanding. Now that I know mine are all but useless, are all of the low impedence injectors plug and play or do they require resistors? Also, if I put my stock chips back in, does anyone think my car would be driveable despite the mods? I'm guessing it would run and not really be driveable due to the cam and lack of fuel supply.
nize 08-15-2007 11:05 AM
as far as i know, the low-impedence injectors are plug-and-play without the need for resistors.
i'm also guessing that your car would be drivable as long as you restore the original injectors.
Flitzr951 08-15-2007 11:13 AM
well I have the stock ones in there right now so I guess I'll find out tonight when I swap out the chips. Thanks for all of the help, I'll keep this thread updated.
Flitzr951 08-15-2007 05:51 PM
So I put the stock chips back in and it started right up and idled fine. It sounded pretty good but a lot of noise IMO. My A/F gauge says I'm still lean. My wastegate dump pipe is not connected to my exhaust pipe, and my WBO2 sensor is located behind that point. So could that be confusing the whole system? I'm guessing I'll need to tune it with the MAFterburner software before I can rev it up etc?
nize 08-16-2007 07:45 AM
good to hear. if you look at the stock location for the o2 sensor, you will see it's after the wg and before the turbo. i've simply replaced mine with a wideband in the same bung with no problems.
you should definitely tune before revving unless you enjoy knock. :)
Flitzr951 08-16-2007 10:59 AM
I might do that, why would they say to install it after the merge?
nize 08-16-2007 11:15 AM
who's 'they'?
Flitzr951 08-16-2007 11:41 AM
The instructions that came with my Innovate kit
nize 08-16-2007 04:17 PM
maybe they meant 'after the merge' meaning 'don't install it in the individual exhaust runners before the merge because then you won't get the combined afr reading' ?
Flitzr951 08-16-2007 08:19 PM
Well I'll see how it goes once I get to the fine details later, either way I need to connect my dump pipe so that's the first step. I'm just waiting for my serial-to-usb adapter to come in the mail so I can upload a tune to my MAFterburner. The cable from LR was useless because my laptop does not have a serial port, has anyone else used a USB adapter with the MAFterburner setup?
soxnail 08-17-2007 05:46 AM
word of caution on the usb to serial converters, some of them do not supply all the voltages needed to properly run a serial port. So if yours is not working you may have to add a 9V battery to it.
Sox
nize 08-17-2007 06:39 AM
sox is correct. i've had many usb>serial adapters fail to work in the past.
Flitzr951 08-22-2007 06:31 PM
So the usb>serial adapter was a bust. I finally got my hands on a laptop with a serial port and loaded a basic tune today. It loaded easily but now the car is back to not idling, it fires up and dies off. I'm pretty sure I can't reset the MAFterburner to the way it was before the tune. This is my first experience with the MAFterburner setup/software so if there are any gurus here that know how I can get it back to idling and work from there, I'm all ears.
nize 08-23-2007 09:43 AM
the exact same maf system can behave differently on different cars, which is why it's not really possible to share one tune between many cars like you can with a map system.
was this car ever running correctly before you took it apart?
maybe this can help?
http://tinyurl.com/27uexy
myskyon on here is a local 951 buddy who is successfully running the lindsey maf with mafterburner. i'll ask him to post.
Flitzr951 08-23-2007 09:49 AM
myskon and I have been talking, I got the tune from him (he's been a huge help). Is the power perfect setup superior to the MAFterburner? I wasn't sure how the software interacted with the MAFterburner console but I've now been told that it's a live feed as long as I have the car connected to the computer. I'm assuming that the Super 75 is leaning out the stock injectors so I'm going to try going more rich accross the board and hope that will at least get it idling where I can dial it in closer.
nize 08-23-2007 10:02 AM
how would the size of the turbo have any effect on the idle? the turbo isn't spooling at idle. :)
i really don't know much about the power perfect or the maf system, as it's never really interested me. :) perhaps give lindsey a call?
and was the car running before you tore into it?
Flitzr951 08-23-2007 11:33 AM
But the air going into the manifold still has to pass through the turbo, I was thinking that if the MAF is not dialed in, the greater volume of the Super 75 would simply be allowing too much air into the engine. The car was running fine when we took it apart, but obviously a lot has changed since then.
nize 08-23-2007 12:40 PM
there is no greater volume when the turbo isn't spinning !
Flitzr951 08-23-2007 12:45 PM
interesting, well I'm going to play with the software and see what happens
Flitzr951 09-09-2007 08:23 PM
So after some digging, I found out that my TPS wire to the MAFterburner was not properly connected. I fixed the connection and it immediately was able to hold a steady idle and rev up (although I'm on stock injectors so the reving is extremely limited). Does anyone have an innovate A/F gauge (w/WBO2)? I had no problem with the calibration but I feel like now that the engine is running, I'm not getting much feedback from the gauge but I've never used it before so maybe I just don't know what I'm looking at.
ae1969 09-09-2007 08:43 PM
.... a little late to the party but......
If you are using the low impedance siemmens injectors get yourself a pair of 1 ohm resistors. The injectors are wired in pairs and you ideally want one resistor per pair.
The stock 951 injectors are an odd ohm 4-5 ohms.... so you use a 1 ohm per pair to get those low ohm injectors close.
In regards to your last question.... If its like any other wideband guage you can blip the throttle and the AFR will jump ......... what display are you using?
I actually have 2 widebands....don't ask. It was all in the name of science. ONe in the stock location and one on the dump pipe. One reads leaner. I will leave that for all the gurus to determine. :D One spot is approximately 0.5 leaner.
P.S Shameless plug - if anyone is looking for three 55lb siemens low ohm injectors with less than 2000 miles on them. CHEAP. I went with a high ohm setup for MS.
nize 09-10-2007 06:31 AM
don't you mean resistors are required if one is using high ohm injectors? otherwise, how would resistors increase ohm if they resist? it makes more sense they'd resist, and decrease ohms.
also, which sensor reads lower? and are they identical make/model sensors of the same age? i'd think as sensors get old/worn, they'd read leaner.
soxnail 09-10-2007 07:00 AM
Resistors add resistance if connected in series (i.e one after the other). They decrease resistance if connected in parallel (i.e next to each other)
Total R = R1+R2....Rn (resistance in series) where R1 and R2 etc. are individual resistances.
Total R = 1/(1/R1+1/R2+1/Rn) (resistance in parallel )
The sensor down stream may read lower if there is any combustion in the dump pipe, or richer if any dilution occurring down stream.
Sox
Flitzr951 09-10-2007 08:20 AM
I get 2 number reading from my gauge. One pops up when the car is firing up/idling (the number is usually around 60) once I turn it off the number starts counting down. The other number is 17.XX (I'm guessing my A/F ratio) But it doesn't seem to let me toggle between the two and keep one up on the display. Also, the "rainbow LED" is always pegged to the right (red).
