Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Guru chips, 88 DME in an 86 951.
I'm wondering if anyone might have an answer, as I'm sure Danno is probably hard to get a hold of.
Somewhere in my car's life it received an '88+ DME, so I have the 28 pin eprom. In reading the Guru instruction(http://members.rennlist.com/jerseyshore944/GURU-ChipKitInstallation.pdf), for the '88 DME there are ignition maps available by using the IA and RCP plugs. However, my '86 harness does not have the IA, it has the RCP plug but no IA in the harness.
My question is this... Since my car has the altitude-compensator(according to instructions), which is what is replaced by the IA, is the chip set going to read as though the IA is plugged in?
Any thoughts or suggestions(aside from a new DME harness)? Don't worry about it?
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 09-21-2007, 03:27 PM
rberry951's Avatar
It will use the first map, should work fine as is.
Russell Berry
1986 911 Carrera Targa Widebody/Slantnose
Old 09-27-2007, 04:10 PM
Thank you sir. It seems to be fine with it.
Eventually I'll use your chips, most likely, but I want to install some goodies before ordering a nice set of custom chips.
Jack
Old 09-28-2007, 09:32 AM
