Can't loosen motor mount bolts
I am trying to change my motor mounts on my 1988 944 Turbo S. I can’t get the top bolts to loosen. The only wrench that fits in a ¼ in rachet, but I can’t get enough leverage to loosen the bolt. Any suggestions.
A quarter inch breaker bar with a pipe over the end to increase leverage.
Good luck, George Beuselinck |
In the Fires of Hell.....
I used a gear wrench to get in there...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Soak it overnight with pb blaster. Do it multiple nights if needed. Old crusty bolts! Good luck!
