Porsche Gonzo
sunroof glitches
i noticed today when i went to remove the sunroof and i could raise and lower it fine, but when the ignition is turned back a notch to allow the panel to be removed the switch no longer funtions. i tried it several times and nothing happened. i tried it 45 mins later and it worked. now it is 50 degrees outside is there some sort of relay that wont allow the roof to come off the car under a certain temp? im kind of doubting there is because its been off the car when its been alot colder. any ideas. possibly seperate relays in the fuse box?
Thank you
1986 928S (we need an excorsism done here) 1988 944 Turbo (2-14-2000 - 6-6-2008) Last Video Made in the 944 turbo (5-28-08) http://www.youtube.com/watch?v=UmjhT7AndEQ |
Nope no temp relay there. You may have an intermittent switch some where.
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
