Porsche Gonzo
Automatic Doors Lock
the car has no factory alarm, but does have central locking. the switch between the seats on locks on unlocks the passenger door.... is that correct becuase when i use the key in the driver door it unlocks both doors
Thank you
1986 928S (we need an excorsism done here) 1988 944 Turbo (2-14-2000 - 6-6-2008) Last Video Made in the 944 turbo (5-28-08) http://www.youtube.com/watch?v=UmjhT7AndEQ |
The switch in the middle should lock and unlock both doors.
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Porsche Gonzo
ok. so if they key can unlock both doors from the drivers door, then the solenoids in the doors work. however the passenger door is the only one locking or unlocking from the center console. i can hear the solenoid firing both directions inside the drivers door when the center console switch is pressed, which leads me to believe of of the 2 mechanical connections has popped lose. thanks sox
the thing is that the key unlocks the driver door and the solenoid unlocks the other door. If the solenoid does not unlock both doors then it goes back to lock. So you need to make sure that the doors are being unlocked by the electronics and not the mechanical turning of the key.
Sox
Porsche Gonzo
the only reason i dont think its electrical is because i can hear the solenoid firing to lock or unlock the driver door from the center console switch. even the knob on the driver door move a little when the solenoid fires. ill go ahead and take it apart and see what i can find. if is electrical i may have to bring it to a porsche shop. wiring rear wiper assemblies is one thing, playing with microswitches is a little harder and if youve taken the door apart you know that you have to be a anorexic midget to get in there :-)
Happy Turkey Day
Agree on the anorexic midget
![]() The electronics are fine if the solenoid fires. The problem is that there is an adjustment in there that sets the travel of the solenoid. When the travel is not enough the lock does not change states (lock or un lock) the key directly turns the lock mechanism and is independent from the lock electronics. If the solenoid is not geting enough travel then the lock will not work. Ps. When I had the door open I replaced the piece that goes from the solenoid to the lock (it is made of plastic and fails) I just made a piece from aluminum. happy gobbling Sox
Porsche Gonzo
i got it. the connector from the solenoid popped off. just get to put it back together but thats easy. thanks for you help
