Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Two Big Problems with my Turbo car
Had the car inspected today...
Compression problem in one cylinder... the other 3 are exactly the same yet one is half the compression of the rest.
Car does not idle weird or anything... but leakdown says that there is either a burnt exhaust valve, or bad spring.
Clutch is near dead
Timing belt is due
About 3k in parts and labour is needed. (seals, clutch, gaskets, valves)
Second big issue is....
driving home.. near empty ..needed gas.. only could find 91 octane, put about 10dollars in (canadian) and start driving and i hear the turbo a LOT louder and the idle is horrible.. down to almost 400rpm and back up to 1100 sits for a sec and back down.. but never died..
is this octane related?
what should i do about the valve issue while im in there... i usually upgrade things when stock brakes... why not go in a little deeper while youre already in it..!
Marcone
Marcone
~87 Turbo ... Vandalized.. now a parts car.
~89 s2 16v ... Getting back on the road soon.
~89 Turbo S ... I GOT ONE.. Hidden away in storage!!
~04 Cayenne S ...
Old 12-19-2007, 08:50 PM
JoshB's Avatar
Man - hopefully that bad compression is not a scored cylinder. That would mean your block is basically a boat anchor.
Better keep your fingers crossed that it is headgasket or valves.....
I would pull the head and have a look.
89 944 - Alpine white/blue, Focus 9 DME and MAF, MSDS headers
Old 12-20-2007, 06:10 AM
Ornery Bastard
91 octane should not cause a problem. I ran 91 during my trip through California because that's as good as it gets there and the car ran fine the whole time.
It definitely would not cause a problem with the idle.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 12-20-2007, 09:35 AM
Easy way to check out the cylinder is to use some compressed air at TDC on that cylinder.
once you get a fitting that will allow you to use about 80-100 psi you should be able to hear where it is coming from. like listen with the TB tube of and see if it is an intake valve , listen from the aos tube to see if it is blowing through the rings or cylinder and then listen out the exhaust to see if it coming through an exhaust valve.
You will also be able to tell if it has a blown HG b/c it will push coolant out the reservior.
However I personally would just pull the head and look at everything. easier to be sure.
Since you have to do the clutch, just drop the engine and cradle and kill a few birds with one stone.
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 12-20-2007, 09:58 AM
I think every one missed it..
We DID do a leakdown and found out its from an exhaust valve.. whether its the actual valve that is burned/chipped or its a spring not working on that valve is the question.
LOL
SO.. i should drop the engine and do it all that way.. i was gonna send it to the shop and do it.. im scared of the turbo stuff.. dotn know it that well.
So secondly the octane shouldnt be the issue.. therefore maybe the leakdown damaged the valve even more?
Lemme know if you know anything
Marcone
~04 Cayenne S ...
Old 12-20-2007, 01:23 PM
LOL
Marcone
~04 Cayenne S ...
Old 12-20-2007, 01:24 PM
Super Moderator
nize's Avatar
if the only problem is the exhaust valve, there is no need to drop the engine. just remove the head and install new valves.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 12-20-2007, 06:08 PM
A little scary the amount of pipes and wiring that goes with this cramped space...
i was cool with the Bmw 6cyl.. but this seems more complicated... probably gonna send it in.
Marcone
~04 Cayenne S ...
Old 12-20-2007, 09:01 PM
You should do it. If you are going to look at building some big HP you should be familiar with everything anyway. Guessed I missed that it was verified that it was an exhaust valve.
It's really not that hard .
You are going to needa clutch anyway.
I would still drop the engine
Sid
Old 12-21-2007, 05:52 PM
Ok... well if i get it out and take it apart myself... which i have done before with the S and S2 models.. and a few beemers.. Im ok with the dis-assembly and re-assembly stuff with normal engines.. might as well bite the bullet with the turbo motor as well...
what should i do to the head to make it better.. if i am sending it in to a head guy anyways to do the valves.. will an angle job help etc... ? Any tips? for the while youre in there obsession i am going to have while i am in there !hahah LOL
Marcone
~04 Cayenne S ...
Old 12-21-2007, 06:13 PM
That Guy
Techno Duck's Avatar
The turbo motor really isnt all that more complicated than the n/a cars with the exception of a few more coolant lines and vacuum lines...and yes spaces are a little more cramped, but its really not bad.
As for the cylinder head, replace the valve guides, and valve stem seals. Have them check for flatness of the mating surface and machine it flat if necessary. Valve jobs really arent necessary but 3 angle or 5 angle valve job couldnt hurt.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-21-2007, 11:30 PM
soxnail's Avatar
Did the problem with the idle just start ? (after the fuel stop).
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 12-22-2007, 07:58 AM
Yes.. did the compression and leakdown test.. drove 20 miles fine... got very near empty which is not a normal practice!...got gas.. now have idle problem.
Havent driven since.
Any ideas?
Marcone
~04 Cayenne S ...
Old 12-22-2007, 08:10 AM
soxnail's Avatar
Could have sucked in some junk into the fuel filter ? Is it surging or just rough ?
Sox
Old 12-22-2007, 08:48 AM
Super Moderator
nize's Avatar
do not forget the steam vent mod while you have the head off. one of the best mods i've ever done;
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Co de=STEAMVENT
Old 12-22-2007, 09:16 AM
Surges ...
Thanks about the steam mod.. never even heard about it.
Marcone
Marcone
~04 Cayenne S ...
Old 12-22-2007, 03:49 PM
Luis de Prat's Avatar
Any ideas?
Before you pull the head, check the injector on that cylinder.
A guy on another forum has an 89 that wasn't running right in one cylinder and it turned out to be the injector.
Old 12-23-2007, 01:23 AM
Super Moderator
nize's Avatar
he already performed a compression test and found one cylinder is down on compression. a bad injector wouldn't affect compression readings. it has to be one of these;
1) intake valve (unlikely, as they rarely fail)
2) exhaust valve (likely)
3) head gasket (likely)
4) piston rings (rare, but possible)
5) scored cylinder (rare, but possible)
i think the head must come off.
Old 12-23-2007, 02:05 AM
Well here's one recent case in which it did. Read for yourself:
low compression in one cylinder caused by faulty injector
You seem eager for the guy to pull the head before checking other possibilities. He hasn't even done a leakdown yet.
Old 12-23-2007, 05:53 AM
not to upset anyone..but ..
I wrote above that i did the leakdown and we already know that its the exhaust valve..
whether its the spring or the actual valve is unknown so far tho.
Marcone
~04 Cayenne S ...
Old 12-23-2007, 08:10 AM
