Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
944 TURBO High Idle
when i turn the car on it idles very high, already tried adjusting the TB but no help, any other ideas on why it would be doing this?
Old 10-26-2011, 09:59 AM
Check for a vacuum leak. There is a good chance air is getting in where it shouldn't.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-26-2011, 10:44 AM
Also my oil pressure gauge is above 5
Old 10-26-2011, 11:24 AM
Mine pegs all the time when engine is above idle speed. When cold it pegs even at idle speed.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-26-2011, 11:45 AM
Vacuum leak here I come...
Thanks for the help, I'll get back to you when I find something
Old 10-26-2011, 01:40 PM
Red Clubbie's Avatar
What should the idle rpm be for a standard Turbo??
Cheers,
Geoff.
1984 911 Carrera.......
Old 10-26-2011, 01:49 PM
i would always adjust mine to 1,000 rpm. or a little below, but as of manufac. spec i have no idea
Old 10-26-2011, 03:52 PM
Mine idols high as well. Its probably my throttle position sensor. I know that it is electronically related because it is erratic in nature. She idols fine at initial cold start-up. (900 rpm). After she gets warm however, on occation the revs will come down real slowly. Then all of a sudden, something "clicks" and she goes tame rpms fall and all is well.
Lemme know what choo find out.
Rick
1988 944 turbo
Old 10-28-2011, 08:26 AM
You should hear a click from your TPS just as your throttle completely closes. You will need to test this with the engine off so you can easily hear it.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 11-01-2011, 10:19 AM
Yeah, it had to do with the tps, I didn't remember I had out my intake in the parts cleaner and had removed it I adjusted it and low idle now, but it's erotic, it just up to 1-2 constantly.
Old 11-02-2011, 01:28 PM
Custom User Title
mikepellegrini's Avatar
The thought of an erotic idle really turns me on!
Sorry. Couldn't help myself...
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 11-02-2011, 06:20 PM
Haha I was at a loss for words, but this erotic is not a good erotic :/
Old 11-02-2011, 08:56 PM
Erratic.
1988 944 turbo
Old 11-03-2011, 10:49 AM
Thank you Rick. Haha, I found some TSBs and going to see if theybhelp out.
Old 11-03-2011, 11:32 AM
840 +/- 40 RPM is the appropriate idle speed for 951s. (Ref: Clarks Garage)
-Joe
Old 11-04-2011, 08:00 AM
