differnce in fog lights usa vs ROW
Hi I can see there is a difference in euro ( rest of world turbo fog lights) and usa market cars!! basic I can see euro have driving lights and fog light and usa just fog lights!!right
But the main question are the glasses pieces same ? is just the inside pieces housing waht change or is different ! right!!! I was looking one euro glass one usa glass they llok same or pretty similar? |
Its the interior of the light that is different.. the wiring too just a little bit.. the lenses are the same.. i have a Jap spec car that became a donor.. its lights fit right in with all the other stuff... just had cooler stuff inside.. like two light bulb areas.. high beams and such..
Marcone |
well to completely right the "Euros" have 3 bulb spots. one turn signal one driving light, and one fog light. I have the Euros installed on my 87 USA car. I had to build a Wire harness for the driving lights to work. and I am now int he posses of building one that has a separate switch inside the cabin to turn them on and off. using a factory fog light switch.
When I went to the euro fog/driving lights, I just had the driving lights wired into the high-beam circuit. I figured that I didn't need a separate switch inside the car for the driving lights since the only time to use them is when I would have the high-beams on as well. They are certainly helpful in night driving out in the country.
I am also going to try to build a new Headlight harness, and a completely new fog / driving light harness. |
| All times are GMT -8. The time now is 06:10 PM. |
